Thread: Golf 1.6 FSI - ECON Button not working
Results 11 to 20 of 25
  1. Re: Golf 1.6 FSI - ECON Button not working
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    VW quoting crazy money for it!!
    £76.94 including the VAT.
  2. Re: Golf 1.6 FSI - ECON Button not working
    134 Post(s)
    2007 Post(s)
    ECP sell a Mahle branded sender (this is part of the Mahle, Hella, Behr "premium line") for less but beware of really nasty cheap ones https://www.eurocarparts.com/search/236440030
  3. Re: Golf 1.6 FSI - ECON Button not working
    Jul 2018
    8 Post(s)
    Well I manged to source an OEM part with seal for a £10! It was in an unopened bag from TPS.
    But after removing the old one and fitting the new one (they do look different, the newer one has a longer cylindrical part than the older one......)
    Still no joy.....guess I need to get it regassed....and then see....
    But I am concerned it's just going to leak out all the gas again.....
    Anyways replacing the sensor can be ticked off the list (condensor / radiator thing is also a new part but not genuine / aftermarket from ECP.....EIS Germany one).
    What should I be doing next to solve this issue?
    If after regas.....and it does same thing again....what should I be looking at? Compressor? Or pipework?
  4. Re: Golf 1.6 FSI - ECON Button not working
    134 Post(s)
    2007 Post(s)
    A competent and trained regas technician will do a vac and leak test before recharging. HOWEVER the compressor used has a party trick... EVEN when fully charged, with no codes and the compressor running it still may not work. This is due to the compressor being a constant drive modulated displacement unit and the modulator failing
  5. Re: Golf 1.6 FSI - ECON Button not working
    May 2017
    Cardiff
    12 Post(s)
    @willdudeuk where did you source the TPS sensor from?
    My AC has just stopped working so thinking of changing the pressure sensor - VCDS shows 0 in pressure meas block.
  6. Re: Golf 1.6 FSI - ECON Button not working
    Jul 2018
    8 Post(s)
    Managed to source one on an online auction site.
    didn’t solve my problem though.
    haven’t had it regassed and tested for leaks so don’t know what the issue is yet.
  7. Re: Golf 1.6 FSI - ECON Button not working
    #17
    134 Post(s)
    2007 Post(s)
    If it is showing zero it is probaly telling the truth AND could also be the cause of the leak.
  8. Re: Golf 1.6 FSI - ECON Button not working
    #18
    Jul 2018
    8 Post(s)
    What measuring block shows the pressure for the ac system?
  9. Re: Golf 1.6 FSI - ECON Button not working
    #19
    May 2017
    Cardiff
    12 Post(s)
    Within the HVAC control module, I used the advanced measuring info screen and you can choose to see whatever info you require.
    After searching on a few forums it seems that the pressure sensor can be the cause of quite a few faults/failures. Will order one and once fitted, continue investigations.
  10. Re: Golf 1.6 FSI - ECON Button not working
    #20
    134 Post(s)
    2007 Post(s)
    I can't remember the number but it is labeled in advanced measuring blocks
  1. econ button on....... no aircon?
    By rhosj in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 19-10-2012, 01:00 PM
  2. ECON Button???
    By curryholic in forum Touran - Sharan - Caravelle
    Last Post: 28-01-2010, 07:55 PM
  3. Please Help Econ Button
    By Phortys in forum Golf Plus
    Last Post: 02-11-2008, 12:32 PM
  4. Question Econ button - when to use?
    By tomjj in forum Golf MK5 - 2004 - 2009
    Last Post: 23-09-2008, 06:56 PM
  5. ECON button
    By noshock65 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-08-2008, 02:20 PM
