Thread: Passat 1.9L won't start after an attempted jump start
  1. Passat 1.9L won't start after an attempted jump start
    Nov 2016
    Ireland
    14 Post(s)
    Mate tried do jump his passat when it wouldn't start, thought it was flat battery, put a booster pack on it and something strange happened with dash lights all dimming, lights shone up again as normal when booster pack disconnected; but then wouldn't even try turn over, ignition comes on but nothing happens when hold the key in to start, it doesn't even click.
    It started with a bump start and drove ok, but as soon as turned it off it wouldn't start again. Just ignition lights come up, no click or anything.
    All the wires / earths from the battery down to the starter and fuse links etc.. all look ok and cleaned them anyway.
    All the fuses in the cabin and in the engine bay are ok.
    What's the best thing to start with, gonna check for power to the starter motor I suppose.
    Can VCDS be used to help with this issue?
  2. Re: Passat 1.9L won't start after an attempted jump start
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    The battery was originally flat & probably isn't much better now.
    Charge the battery slowly ( say 5 amps ) for a number of hours until you get it's voltage above 14v.
    Then try starting it again.
  3. Re: Passat 1.9L won't start after an attempted jump start
    Nov 2016
    Ireland
    14 Post(s)
    But even trying to jump it the battery doesn't even try
  4. Re: Passat 1.9L won't start after an attempted jump start
    Feb 2020
    Bradford
    41 Post(s)
    Yep, seen a car last week not starting even with jump leads on but with new battery it starts. They can get damaged beyond hope, not saying yours is this bad but it can happen. I wouldn't trust a battery that has been dead.
    However you say there is no click and that indicates the starter solenoid not engaging, if so it points to an electrical problem with the wiring, relays, switches or the starter itself. First thing to check would be if 12v is reaching the starter (on the smaller gauge wire) when you turn the key to start
  5. Re: Passat 1.9L won't start after an attempted jump start
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Quote Originally Posted by TdiBlacky140 View Post
    Ours was like that until I left it with a good sized, engine running "donor" vehicle connected for 10 minutes or so before trying to start it. Annoying for the neighbours but got the job done .
    After that I put a conditioning CTEK charger on it for a couple of weeks, and it now starts normally after a week or two of non-use. It's a bit laboured at times (as it has always) been so I pop the CTEK back on occasionally for a couple of days "just in case".
  1. Jump start damage?
    By Northernstar002 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-11-2016, 02:40 PM
  2. Using My Allroad To Jump Start Another Car
    By motionpotion in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-06-2013, 09:15 PM
  3. Help! Car wont start after attempted injector replacement
    By f2raf in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-10-2012, 06:16 PM
  4. Please Help passat mark 5 , wont turn over , wen jump start, lights dont work
    By Al_Killya in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-10-2009, 02:38 PM
  5. Please Help abs warning after jump start
    By chrismaher2007 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2008, 11:26 PM
