Thread: Headlight Issue / Possible Water ingress
  1. Headlight Issue / Possible Water ingress
    Aug 2018
    Hi Everyone,
    I have recently purchased a 2018 A6 Black Edition 2.0tdi 30K. The windscreen was smashed at it was left to the elements for a week or so. When I got it the carpets were wet but not saturated. I have been running a dehumidifier for a few days. The issue is OS headlight does not seem to work sometimes when starting and turning off the indicator in the headlight stays on with a solid colour no flashing and other times nothing. I have checked every fuse on the car and all seem fine.
    Can anyone suggest any ideas?
    Nick
  2. Re: Headlight Issue / Possible Water ingress
    Aug 2013
    Dalry - Ayrshire-Scotland
    30 Post(s)
    The led lights do seem to be sensitive to water ingress/ damp. Had plenty problems with the rear led lights... letting in water and going bad: recently replaced a rear unit for this reason. Worth removing the front unit and totally drying it out by keeping it in a warm place for a period / number of days (near a CH boiler?) See if that brings it back to life. There is the danger that the LED cells or related circuit boards are corroded etc... in which case it would be a replacement unit I’m afraid. Good luck.
    A6 Black Edition - 2014 - 2.0 TDI Manual
    Daytona Grey Pearl, Full LED Headlights, Technology Pack, Advanced Key
    4 Zone Climate Control & Heated Seats, Colour DIS, Lighting Pack - LED Ambient Lighting.
  3. Re: Headlight Issue / Possible Water ingress
    Oct 2018
    London
    29 Post(s)
    Replace the windscreen then do a warranty claim
  4. Re: Headlight Issue / Possible Water ingress
    Aug 2018
    Thanks for the suggestions. I do not think there is any water in the headlight but wonder if there are any earth points under the front carpet sections, although pretty certain they are dry now.
    Like the idea of the warranty, sneaky! Could it be fuses 8 and 10, I only seem able to find them for a saloon which I guess would still be in the passenger side fuse box and are for the headlight range and power output for the headlight. Only issue is there seems to be one fuse for both and given the passenger headlight works fine not so sure?
    Nick
  5. Re: Headlight Issue / Possible Water ingress
    Aug 2018
    Hi Everyone,
    Just had a scan complete.
    Could anyone assist with analysing it. Trawling through other information I located the 2 thermal fuses in the drivers footwell behind the bonnet release but do not know if they are part of the problem or are functioning or if you can test the circuit by temporarily replacing with a conventional fuse. They are both 15 amp. Swapping them over did nothing.
    I know the battery is low and I will replace that too.
    Wednesday,25,November,2020,10:23:58:00338
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
    VCDS Version: 20.4.2.0 HEX-NET CB: 0.4513.4
    Data version: 20200730 DS317.0
    Ross-Tech: Home
    VIN: WAUZZZ4G6JN047205 License Plate:
    Mileage: 47474km-29498mi Repair Order:
    Chassis Type: 4G-AU57 (4G5)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 47 52 53
    55 5F 62 6D 72 AC
    VIN: WAUZZZ4G6JN047205 Mileage: 47474km-29498miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    20-High Beam Assist. -- Status: Cannot be reached 0100
    28-HVAC, Rear -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: Malfunction 0010
    5F-Information Electr. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    AC-Reductant Control -- Status: OK 0000
    Address 01: Engine (J623-DDDA) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 021 HA HW: 04L 907 309 AA
    Component: R4 2.0l TDI H20 4166
    Revision: 8DH20---
    Coding: 12254012242401080000
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ECM20TDI01104L906021HA 004005
    ROD: EV_ECM20TDI011_AU57.rod
    VCID: 6B96CF058284A2DED6-803E
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
    Part No SW: 4G1 927 153 G HW: 0CJ 927 156
    Component: 0CK 20TDI RdW H05 0001
    Revision: --H05--- Serial number: 0000000131
    Coding: 100001
    ASAM Dataset: EV_TCMDL382021 002028
    ROD: EV_TCMDL382021_VW51.rod
    VCID: 2E100611711617F6B1-807A
    Manual Transmission Fluid Pump:
    Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
    Component: V553 MTFP 003 0576
    Serial number: 75145041170256002221
    Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
    Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
    Component: ESP9 Premium H01 0530
    Revision: -------- Serial number: --------------
    Coding: 06A29E41604579829B00
    ASAM Dataset: EV_ESP9BOSCHAU57X 004018
    ROD: EV_ESP9BOSCHAU57X.rod
    VCID: 41CA4DADD088988E5C-8014
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
    Component: BCM2 2.0 H61 0825
    Revision: 00002001
    Coding: 01B9704E000000000000
    VCID: 7CB4FC59FFEA35664F-8028
    Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
    Component: J764 ELV MLB H40 0046
    Serial number: 3217000178380016
    Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
    Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
    Component: KLIMA 4 ZONEN H14 0113
    Serial number: 01101700040830
    Coding: 34220978210000
    ASAM Dataset: EV_AirCondiComfoUDS 003008
    ROD: EV_AirCondiComfoUDS_003.rod
    VCID: 6386A7256A54EA9E6E-8036
    Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
    Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
    Component: BCM1 2.0 H20 0368
    Revision: 1502003S Serial number: 00001779808401
    Coding: 0105001440349FE041014083800018000F9DC7082F08020100 000894E100140200400024030000
    VCID: 74A4D479D7BA7D2607-8020
    Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
    Component: WWS57X 170716 H38 0080
    Serial number: 170822094522
    Coding: 0045F7
    Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
    Component: G397_RLFS H06 0002
    Serial number: 20506013X81A955547A0
    Coding: 02006D
    Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
    Component: E1 - LDS H07 0044
    Serial number: 21 09 2017 00001541
    Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
    Component: AQ_Hum_Sensor H02 0007
    Serial number: 6A129DC800PAG0MUFU03
    3 Faults Found:
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 47474 km
    Time Indication: 0
    Date: 2020.11.25
    Time: 10:20:36
    03455 - Function Restriction due to Faults in Other Modules
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 47474 km
    Time Indication: 0
    Date: 2020.11.25
    Time: 10:20:37
    03186 - Front Footwell Lights
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 47474 km
    Time Indication: 0
    Date: 2020.11.25
    Time: 10:20:38
    Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
    Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
    Component: Airbag10.43 H83 0098
    Revision: -------- Serial number: 003P100ESG56
    Coding: 30333130313630323639554A305234473053
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_VW51.rod
    VCID: 3B363F45B264F25E06-806E
    Crash sensor for side airbag: driver side:
    Serial number: 3575HRB401C5BEVOCH2-
    Crash sensor for side airbag: front passenger side:
    Serial number: 3585HRB401E5BEA689K6
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3515JRB40185BKTUO1I7
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3525JRB40185BKTUG20Q
    Crash sensor for front airbag: driver side:
    Serial number: 3554VRB404R51756705S
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564VRB404R517562OEE
    Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
    Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
    Component: Lenks.Modul H06 0005
    Revision: C0068538 Serial number: 91560QIT000N0
    Coding: 000035
    VCID: 3B363F45BA64F25E06-806E
    Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
    Component: E221 - MFL H08 0010
    Serial number: 19 09 2017 D0031779
    Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
    Part No SW: 4G8 920 951 E HW: 4G8 920 951 E
    Component: MDieGb H44 0604
    Revision: 34450315 Serial number: 658200917592048
    Coding: 33A615000B412600010000
    ASAM Dataset: EV_RBC7KMID 004050
    ROD: EV_RBC7KMID.rod
    VCID: 32281261652E3316D5-8066
    Address 19: CAN Gateway (J533) Labels:* None
    Part No SW: 4G5 907 468 K HW: 4G0 907 468 AC
    Component: J533--Gateway H15 0110
    Revision: -------- Serial number: 00000002743862
    Coding: C0CD074418
    ASAM Dataset: EV_GatewPkoUDS 002011
    ROD: EV_GatewPkoUDS_002_AU57.rod
    VCID: 3D32315DAC70FC6E38-8068
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
    Component: J367-BDMHella H10 9070
    Serial number: 0384685304
    Voltage stabilizer:
    Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
    Component: J532_DCDCStab H23 0022
    Serial number: 170716000000000001D6
    1 Fault Found:
    5701 - High Beam Assistant Control Module
    U1070 00 [009] - No Communication
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 47474 km
    Date: 2020.11.25
    Time: 10:20:36
    Voltage terminal 30: 11.6 V
    Voltage terminal 15: 11.5 V
    Control Module temperature: 18 ∞C
    System status: Terminal 15 on
    IN ESP_standstill flag: standstill detected
    Engine running: OFF
    IN ZAS_Te_X: On
    Terminal 15 status via CAN: On
    Terminal 15 status: On
    Datenfeld: 0
    Address 20: High Beam Assist.
    Cannot be reached
    Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
    Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
    Component: KLIMA FOND H08 0113
    Serial number: 02101700040948
    Coding: 22
    ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
    ROD: EV_ClimaContrUnitRearUDS_003.rod
    Address 36: Seat Mem. Drvr (J136) Labels: None
    Part No SW: 4G8 959 760 HW: 4G8 959 760
    Component: MEM-FS H03 0157
    Revision: AA000000 Serial number: 00000278298085
    Coding: 0078130000006001000001010101102030303232203232
    VCID: 77BEE375C6CC163E22-8022
    Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
    Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
    Component: SARA 3D H04 0056
    Revision: -------- Serial number: EJ1BPA720Z8X1.
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_SARA2 005012
    ROD: EV_SARA2.rod
    VCID: 332617659A343A1EDE-8066
    Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
    Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
    Component: TSG FA H03 0511
    Coding: 011C16015E01620002080002
    VCID: 47DE53B5F6ACA6BE92-8012
    Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
    Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
    Component: RCevo H55 0202
    Revision: 00000002 Serial number: 0000141866
    Coding: 101000010001
    ASAM Dataset: EV_RCEPS 106007
    ROD: EV_RCEPS_106.rod
    VCID: 3A383A41BD5ECB561D-806E
    Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
    Revision: 00002001 Serial number: 0456508912
    Coding: 013B0622A0B93080C320098400010F47000000000000000000 0000000000
    Subsystem 1 - Part No: 4G0 951 177 B
    Component: Sensor, DWA 005 0002
    Subsystem 2 - Part No: 1K0 951 605 F
    Component: LIN BACKUP HO H01 0008
    Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
    Component: Dachelektroni H10 0100
    Serial number: 0000000AP00038221092
    Coding: 010000
    1 Fault Found:
    00216 - Signal EC-mirror Fade Out
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 47474 km
    Time Indication: 0
    Date: 2020.11.25
    Time: 10:20:38
    Address 47: Sound System (J525) Labels: None
    Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
    Component: BOSE-G3-C7 H07 0160
    Revision: CJ007001 Serial number: 00000000213938
    Coding: 030000
    VCID: 1D72D1DD04B09C6E18-8048
    Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
    Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
    Component: TSG BF H03 0511
    VCID: 46C05EB1F1A6BFB669-8012
    Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
    Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
    Component: EPB-4 H01 0018
    Revision: -------- Serial number: 00000002319293
    ASAM Dataset: EV_ParkiBrake 001033
    ROD: EV_ParkiBrake_VW51.rod
    Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
    Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
    Component: MxB-ECU 001 0100
    Coding: 04FE02102A600200
    ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
    ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
    VCID: 342414799F3A3D26C7-8060
    Led Headlamp Powermodule Left:
    Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
    Component: LED LeiMo li. H07 7560
    Coding: E01E00
    Led Headlamp Powermodule Right:
    Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
    Component: LED LeiMo re. H07 7560
    Coding: E01E00
    3 Faults Found:
    13705491 - Databus
    U1121 00 [137] - Missing Message
    [Timeout CAN-Message FLA_01 (0x645)]
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 47474 km
    Date: 2020.11.25
    Time: 10:20:39
    13706047 - Databus
    U1123 00 [137] - Received Error Message
    [Empfangener Fehlerwert im Signal LV_Abblendlicht_re_def]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 47474 km
    Date: 2020.11.25
    Time: 10:20:45
    5538308 - Bulb for Low Beam Headlamp Right
    B1218 13 [137] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 47474 km
    Date: 2020.11.25
    Time: 10:20:39
    Address 5F: Information Electr. (J794) Labels: Redir Fail!
    Part No SW: 4G1 035 192 F HW: 4G1 035 192 A
    Component: RMC Nav Plus H62 0186
    Coding: 010101010141DB47082B060301020100000000
    VCID: 2600FE3151E65FB649-8072
    Subsystem 1 - Part No: 8X0 919 884 K
    Component: P38-50-16.03 0001
    Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
    Component: DU6 Basic H43 0084
    Serial number: 9464G20H2819165
    Subsystem 3 - Part No SW: 4G2 919 610 E HW: 4G2 919 610 E
    Component: E380 BDT C7 H20 0250
    Serial number: 90349QID000VA
    Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
    Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
    Component: TSG HL H03 0511
    Coding: 010814004001620002080002
    VCID: 49DA558DE0B850CE84-801C
    Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
    Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
    Component: HDSG-Modul H05 0152
    Revision: 14005001 Serial number: 255700049
    Coding: 093205C010
    ASAM Dataset: EV_HDSGAu572 001022
    ROD: EV_HDSGAu571.rod
    VCID: 36202E7189462F36F9-8062
    Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
    Component: TSG HR H03 0511
    Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
    Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
    Component: SCR-Stg-G2 H10 0013
    Revision: 00000000 Serial number: 172220099
    ASAM Dataset: EV_RDCMA00100 008040
    ROD: EV_RDCMA00100.rod
    VCID: 2F2E1B15761C1EFEBA-807A
    End----(Elapsed Time: 01:56, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
    Nick
  1. Please Help Water ingress
    By muffster in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-02-2018, 03:11 PM
  2. Question Water ingress
    By AudiA3T in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 15-12-2016, 10:41 PM
  3. Replies: 4
    Last Post: 28-11-2015, 12:35 AM
  4. Water Ingress In My 80 TDI?
    By jacksticks in forum 80 - 90
    Last Post: 22-02-2015, 06:03 PM
  5. 1.9 Tdi Water Ingress
    By paulp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2007, 09:15 AM
