Thread: Sounds like a boing noise turning steering
  1. Sounds like a boing noise turning steering
    Oct 2020
    Ireland
    Hi
    2009 passat and when I turn steering left or right there is a noise made that sounds like a spring noise for a second... Turn it further and another similar noise.
    Inspected spring yesterday and doesn't appear broken.
    I have a short video of the noise I can dm anyone if they could help me.
    Wondering is strut mount failure is often or would even drop link make similar noise?
  2. Re: Sounds like a boing noise turning steering
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by Georgedawes View Post
    Hi
    Could be a number of things, springs can move if held down by a smooth bearing mount, front drop links can twang as they are attached to the anti roll bar each side, even steering track rod ends can transmit sound through the inner rods and through the steering box. A worn ball joint is likely to knock not twang so would be a different sound. Bad bearings under the top mount can make noise when turning as it will be transmitted through the spring / strut. Passat top mounts are normally pretty robust and in a lot of cases the bearing ring that fits under the mount fails way before the top mount rubber and casing. In rare cases the rigid metal in the top mount has been distorted by impacts to the running gear or by drawing the strut in using the bolts which is a bad method of installation.
    Mad Mitch
  3. Re: Sounds like a boing noise turning steering
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Mine sounded exactly like that when the top of the spring broke.
    The last half turn of the spring broke off & speared through the mount bearing.
    Was very difficult to see when on the car.
    New spring & top mount fixed it.
  4. Re: Sounds like a boing noise turning steering
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Quote Originally Posted by philipharmes View Post
    Similar for us. It took a bright torch and some good peering to see the top end was fractured, not smooth.
  1. Please Help Noise when turning steering wheel.
    By Sullydog in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-04-2017, 07:41 AM
  2. Noise when turning the steering wheel
    By takksi in forum Golf MK6 - 2009 - 2013
    Last Post: 29-09-2014, 01:01 PM
  3. Noise when turning steering wheel
    By Bazaar in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-04-2014, 10:49 AM
  4. Horn sounds when turning the steering wheel
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-05-2010, 06:34 PM
  5. HELP! Steering noise - sounds like a milk float! Any ideas?
    By MC72 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-10-2007, 03:59 PM
