Re: A3 Reverse Sensor –
23-10-2020,02:07 PM
Originally Posted by
Phocker
My A3 has started having an odd issue. After I start the car when I put the gearbox in reverse I get a long tone, instead of the short beep to let me know it is in reverse. Then the parking sensors don't work, and any subsequent shift into reverse I no longer get the short beep that it is in reverse. I have no faults on the dash, and OBD11 does not give me any faults.
Any ideas?
Is it an OEM parking sensor setup or an aftermarket one? If it's OEM, you should get the car scanned by someone with VCDS to find out if it is a sensor gone faulty (most likely) or the controller.
Cheers!
MF.
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
