Thread: Golf Mk4 VR6 4Motion - Oil Sensor Workshop - Yellow oil can - Message Displayed HELP Please
Results 1 to 1 of 1
  1. Golf Mk4 VR6 4Motion - Oil Sensor Workshop - Yellow oil can - Message Displayed HELP Please
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All,
    Well my wonderful Golf Mk4 VR6 4Motion 2003 year - decided to display on the clocks - 'Oil Sensor Workshop' - Yellow oil can and EPC light illuminated - I have checked the engine oil level using the dipstick and the level is normal.
    I have completed a scan and got the below faults:
    Address 17: Instruments
    VCID: 285F9E85C8228801A7-5140
    WVWZZZ1JZ3D014338 VWZ6Z0B0246226
    4 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    30-10 - Open or Short to Plus - Intermittent
    00667 - Ambient Temperature Signal
    30-00 - Open or Short to Plus
    01330 - Central Control Module for Central Convenience (J393)
    49-10 - No Communications - Intermittent
    00562 - Sensor for Oil Level/Temperature (G266)
    I presume this is the important one
    I have cleared fault codes - then cycled the ignition 3 or 4 times then the message returns
    I also noticed the CLIMAtronic unit has stopped working - not sure if this is connected or not?
    I also noted the following faults in the Engine module:
    Address 01: Engine
    VCID: 51A91361CB38A9C910-515E
    3 Faults Found:
    16795 - Secondary Air Injection System
    P0411 - 002 - Incorrect Flow Detected
    17819 - Secondary Air Injection System; Bank 2
    P1411 - 002 - Insufficient Flow
    16955 - Brake Switch (F)
    P0571 - 008 - Implausible Signal
    All help greatly received Thanks All
  1. emssions workshop dash message
    By JimC64 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-05-2011, 11:18 AM
  2. 01 Passat TDi Engine Workshop! Message??
    By alba_tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-02-2010, 03:04 PM
  3. Possible Solution: Emissions Workshop message on dashboar
    By andrew_jmdata in forum Golf MK4 - 1999 - 2004
    Last Post: 12-12-2009, 03:07 PM
  4. Emissions Workshop message
    By Llanesra in forum Golf MK5 - 2004 - 2009
    Last Post: 03-04-2009, 04:25 AM
  5. Engine workshop! warning message
    By deezal in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-10-2008, 09:23 PM
