Thread: Audi A6 C7 Boot Indicator flicking
  1. Audi A6 C7 Boot Indicator flicking
    Sep 2020
    Leicester
    Hi. So this morning on way home i had rear indicator bulb message pop up. Upon investigation the rear left boot indicator is flickering faintly when indicating. The actual indicator on the side at the back is fine though, just the left rear indicator section on the actual bootlid is flickering.
    Can this bulb be changed or does this mean whole new unit? Iv looked at videos of how to remove but as its raining will attempt when its not.
  2. Re: Audi A6 C7 Boot Indicator flicking
    Aug 2013
    Dalry - Ayrshire-Scotland
    30 Post(s)
    Here is a link to a similar thread. These units are sealed and need to be replaced (unless you are a serious fixer..see thread ) The valeo manufactured OEM unit is c£200... tho you can get lest costly after marker units.
    Rear lights
    A6 Black Edition - 2014 - 2.0 TDI Manual
    Daytona Grey Pearl, Full LED Headlights, Technology Pack, Advanced Key
    4 Zone Climate Control & Heated Seats, Colour DIS, Lighting Pack - LED Ambient Lighting.
  3. Re: Audi A6 C7 Boot Indicator flicking
    Sep 2020
    Leicester
    Can i ask if anyone can help, but does the wiring for the rear lights run down the passenger side at all? Im not convinced the whole rear light boot lid cluster needs changing as al lights work apart from the indicator strip flickering inline with indicator.
  4. Re: Audi A6 C7 Boot Indicator flicking
    May 2013
    Quote Originally Posted by Suri66 View Post
    I have that bulb error, but the indicators visually are fine. Previous reading suggested in my case it’s probably moisture in the light unit and the errors reading a resistance difference. Audi, suggested the control unit had failed . Because there’s no visual failure, I am just living with the bulb error for now.
    A6 Avant S-Line BiTdi | born Sept '13 | advanced tech pack | sports diff | privacy glass | 75l fuel tank | lighting pack | HB assist | rear cam
    Q5 S-Line Plus TFSI | born April '11 | tempted to add stage 1 Revo taking HP from 177 to 290.
  5. Audi A6 C7 Boot Indicator flicking
    Aug 2013
    30 Post(s)
    I had the same error with an intermittent fault on both the indicator and the side light elements of the unit.
    I agree that water ingress is the issue.
    I bought a replacement unit online; as I had a MOT this week. Replacement is not OEM.. but half the price etc.. the makeup of the lighting tubes, inserts is as the original so know worries it looks substandard etc.
    see attached pic.
    Fitting is fairly straightforward tho problem is getting a watertight seal against the boot aperture. When fitted; a short time later water noticed on inside of new light unit. It’s currently taken back off the car and drying out: Will try again shortly. It did cure the fault/error lights etc.
  6. Re: Audi A6 C7 Boot Indicator flicking
    Sep 2020
    Leicester
    Ok. Interesting update. I had condensation in that rearlight which seems to have cleared up by itself due to a dry day. The rear indiciator is now working normally with no error lights. Only thing now is to still remove it and buy some kind of clear sealant to seal any miniature hole there could be.
  7. Re: Audi A6 C7 Boot Indicator flicking
    Aug 2013
    30 Post(s)
    My new unit is fitted including the use of a mastic sealant... (which is going to be messy if it ever needs to come back off. ) All is now quiet/working even including fact it is pretty wet weather at the moment.
  1. Replies: 3
    Last Post: 11-09-2014, 08:54 AM
  2. Question VW Passat B5 - ABS - Dash warning light flicking on intermittently
    By godon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-02-2012, 06:07 PM
  3. Dashboard flicking on and off
    By nickobank in forum Audi A3 - Archive Topics
    Last Post: 21-09-2008, 03:12 PM
  4. A4 Cab boot indicator
    By daz2vans in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-07-2008, 11:11 AM
  5. Boot open indicator
    By MickM in forum Audi A4 - Archive Topics
    Last Post: 18-08-2007, 12:18 AM
