Thread: ACC and Audi Brake Guard Unavaliable.
Results 11 to 20 of 22
  1. Re: ACC and Audi Brake Guard Unavaliable.
    Sep 2009
    Lincoln, England
    6 Post(s)
    Get a quote from a car repairer, they have the kit to set them up after shunts. Some have the same dealer spec kit.
    Sent from my SM-G988B using Tapatalk
  2. Re: ACC and Audi Brake Guard Unavaliable.
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Driver side radar unit is a touch expensive.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: ACC and Audi Brake Guard Unavaliable.
    May 2013
    Quote Originally Posted by dean warren View Post
    For me getting a similar if it the same resolved was al about having ACC, unlike cruise it’s magic. While not a fan of brake guard, it’s served it’s value on one occasion, so I’d rather have it operational than not.
    Your radar fault rear or front? The rear bumper has no idea if it’s removed. I am not sure the front does, i suspect it only knows if the car is powered on while the sensors are unplugged. I saw a guide instructing to disconnect the battery to avoid this issue when removing the front bumper.
    If the rear radar sensors, they require a level 2 of calibration compared to the front... that is an additional unit positioned in exactly the right position for the rear radar to sensors. The unit creates a Doppler effect and somewhere on the forums a chap made his own with a fan... I’ve been unsuccessful finding a crash repair shop to calibrate for less than £350. Plenty claiming they can for less but with further questions they actually can only do the front.
    Apparently if you replace the rear radar units as a pair (from a donor vehicle) they will work without calibration*. I replaced one, despite being identical in hard and software revision numbers, it still required calibrating.
    Should your windshield need replacing, the front will be calibrated.
    *it’s always advised to calibrate, if where they car had crash avoidance, the difference in a few degrees could supposedly contribute to the car putting your car into an accident rather than avoiding.
    A6 Avant S-Line BiTdi | born Sept '13 | advanced tech pack | sports diff | privacy glass | 75l fuel tank | lighting pack | HB assist | rear cam
    Q5 S-Line Plus TFSI | born April '11 | tempted to add stage 1 Revo taking HP from 177 to 290.
  4. Re: ACC and Audi Brake Guard Unavaliable.
    Dec 2007
    44 Post(s)
    Mine are front, i did not know there were some cars with rear fitted, are they visible like the front? I have a mark on my front bumper i wanted painted so will get that done now as the radar just screw in from the front, I really miss cruise control, i wished the car would default to standard cruise if the acc failed instead of no cruise at all.
  5. Re: ACC and Audi Brake Guard Unavaliable.
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    You can buy a 2nd hand unit and have the component protection removed at the same time as the calibration. I can remove component protection for you but i cant calibrate it. if you want to take a trip up to doncaster i can put you touch with a friend of mine who can do both for you.
  6. Re: ACC and Audi Brake Guard Unavaliable.
    Dec 2007
    44 Post(s)
    Quote Originally Posted by morski View Post
    Ive just ordered a 2nd hand unit, so this has CP too? Lol great.
    I may need to take you up on the offer.
  7. Re: ACC and Audi Brake Guard Unavaliable.
    #17
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Yes defo on the CP. As long as you ordered the same unit with the part number and its from a reputable source CP can be removed.
  8. Re: ACC and Audi Brake Guard Unavaliable.
    #18
    Sep 2009
    Lincoln, England
    6 Post(s)
    The rear radar units are blind spot monitoring and not related to acc
  9. Re: ACC and Audi Brake Guard Unavaliable.
    #19
    Dec 2007
    44 Post(s)
    My blind spot system has stopped working too though, although no faults
  10. Re: ACC and Audi Brake Guard Unavaliable.
    #20
    May 2013
    Quote Originally Posted by stig414 View Post
    Stig, if you’ve got them don’t tempt fate... Yes they’re for side assist, but if you have them they must work for ACC to operate. Rather than replace, I tried decoding them but no luck, had to fix.
  1. Question New 3.0 TDI owner - issues with acc / brake guard / start stop
    By Classic1 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-12-2018, 11:32 PM
  2. Q7 acc not available!! Brake guard off after fitting westfalia towbar
    By Waverunner52 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 19-01-2017, 12:42 AM
  3. corroded rear brake splash guard
    By quinya3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-03-2014, 08:17 PM
  4. Question ACC with Brake Guard...?
    By AGW82 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-04-2013, 07:46 AM
  5. Dog Guard for Audi 80 1.9 TDI Estate?
    By mangojuice in forum New Member Introductions
    Last Post: 27-02-2008, 10:01 PM
