Thread: Carbon Clean / DPF Clean
  1. Carbon Clean / DPF Clean
    Sep 2020
    Leicester
    Hi all. Ok so having had my C7 2.0 Ultra TDI. I recently had a minor service done along with the cambelt and water pump. Im considering seriously about having the Carbon and DPF cleaning done as i found someone who will do both for £99. My car has done 62k and want to know if the fact i had oil change as part of service is an issue in regards the Carbon & DPF clean?
  2. Re: Carbon Clean / DPF Clean
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    So someone is going to take the DPF off, professionally clean it, fit it back on and test it for £99.00? Bargain!
  3. Re: Carbon Clean / DPF Clean
    Feb 2020
    Bradford
    41 Post(s)
    If its not broken I'd definitely advise you not to fix it. If there is issues you are trying to address than that's a different story.
    With regards to the oil change, only use the correct low saps oil, If in doubt get that changed to the correct one
  4. Re: Carbon Clean / DPF Clean
    Sep 2020
    Leicester
    Well the dpf clean is more chemical based i think rather than taking it out and cleaning it. I think i will leave the carbon clean for now as it should ideally be done before an oil change.
    The only only reason i askd about the dpf clean was becuase the particulate warning came on today coming back from town but disapeared itself after 2 miles. Made me worry after only owning car for 2 weeks there was something wrong so trying to find best way to tackle problem if any. Is chemical based cleaning good any good?
  5. Re: Carbon Clean / DPF Clean
    Feb 2020
    Bradford
    41 Post(s)
    Quote Originally Posted by Suri66 View Post
    Don't think there is any problem. If yours is like our 2016 GTD the dpf light is pretty interactive. Dpfs don't like stop start driving they need a good run - which seems it was only 2 miles on your car and that's not bad at all.
  6. Re: Carbon Clean / DPF Clean
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi. You do not get an indication that the DPF is regenning, with experience you notice a slight loss of power when it’s happening. The warning comes up if the DPF is around 25% full or regents do not complete due to short runs,you will know if it’s trying to do one when you stop the car as the cooling fans will keep running. I read somewhere that the clean happens around every 320 miles. The best thing to do is give it a good long run at speed, only up to 70 he he, say 20-30 miles. If the warning comes on again keep it running put it in sport and do at least 10 miles like that again at speed if you can. The other way to tell if it’s doing a regen is the idle rpm will go from 800 up to 1000 when stoping if it dose keep driving until it drops back to 800. As the old saying goes, give it a good clean out thrash every now and then, blow the cobwebs away. Good luck.
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  1. Carbon clean
    By daveplyjeep in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-04-2019, 02:25 PM
  2. Carbon clean
    By mattyk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-02-2019, 04:00 PM
  3. Hydrogen carbon clean vs terraclean
    By sam2k01 in forum 2.0TDi - Engine
    Last Post: 21-11-2014, 10:04 AM
  4. Get Your Pipes Sparkling Clean With Green Glass Clean!
    By usersight in forum General Detailing/Cleaning Questions
    Last Post: 16-11-2009, 12:12 PM
  5. How to clean and keep clean Light Beige Phoenix Cloth interior
    By ackerman821 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2008, 04:36 PM
