Thread: new audi A6/sd card map update
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: new audi A6/sd card map update
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    Quote Originally Posted by johnsimcox View Post
    You are correct you do not have the Tech Pack, you have the RMC system. Gav28uk does have the Tech Pack and his comment regarding a softare update only applies to cars with Tech Pack
    Thanks for the clarification John, that makes sense. I know you need the MIB2 MMI setup, so can you not get that if you don't have the tech pack?
    Audi A6 Avant 2019 Black Edition, C8, 3.0TFSI S Tronic. Tech Pack, Parking Pack, Tow Bar, Tour pack.
  2. Re: new audi A6/sd card map update
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi not 100% on this but, Tech pack is completely different hardware HDD rather than SD card so would expect any firmware or software versions are not compatible between the systems.
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  3. Re: new audi A6/sd card map update
    Oct 2015
    Banbridge
    10 Post(s)
    ok thanks for that
  4. Re: new audi A6/sd card map update
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by gav28uk View Post
    MIB2 was introduced to the C7 as part of the facelift and the move (for the HDD version of the MMI) from 3g to 4g/LTE. The RMC system, continued largely unchanged at the facelift and thus does not use MIB2. There are some who offer Carplay for RMC, but it requires hardware and seems to cost £500+ just for the hardware
  5. Re: new audi A6/sd card map update
    Oct 2015
    Banbridge
    10 Post(s)
    good info guys but can i tell which map version i have as car is not from Audi but an indie
  6. Re: new audi A6/sd card map update
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by Kevmc63 View Post
    YTou mentioned previously that you had the SD card based navigation so therefore it is the RMC system. Regarding map version go into the car menu and then I think (not had myt c7 for nearly 2 years so doing this from memory) go to SETuP MMI and then there is an Option for VERSION INFORMATION. You want to look at the Navigtion Database Version.
    Be careful buying an SD Card with new map data online as it is not simply a case of unplug one and plug the new card in. The card needs to be activated for the vehicle and officially only Audi can do this as it requires a link to the factory systems. People have found a way round this but you will need someone who knows what they are doing
  7. Re: new audi A6/sd card map update
    #17
    Oct 2015
    Banbridge
    10 Post(s)
    Ok sound advice there thanks��
  1. Please Help Map Update via SD Card failing
    By DanD3 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 30-10-2022, 11:38 AM
  2. Question MMI Navigation Maps update via SD Card
    By John Norris in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 21-11-2015, 09:11 AM
  3. Update maps via sd card
    By tonye60 in forum A7 - S7
    Last Post: 26-05-2015, 05:06 PM
  4. Sd card update Saad
    By tonye60 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 14-05-2015, 03:51 PM
  5. SD Card Sat Nav Update Cost
    By johnsimcox in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-04-2014, 01:38 PM
