Thread: new audi A6/sd card map update
Results 1 to 10 of 17
  1. new audi A6/sd card map update
    Oct 2015
    Banbridge
    10 Post(s)
    so at last i have got my A6, 2015 avant 2.0 tdi ultra in misano red with black pack, was looking at the sat nav which is sd card based and audi are looking £300 to update it if its not the 2020 version,
    how do i know if its the latest? and any other options (cheaper) to update it.
    thanks
  2. Re: new audi A6/sd card map update
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Ebay..... loads on there, the listings also tell you how to check what u have if i recall.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: new audi A6/sd card map update
    Oct 2015
    Banbridge
    10 Post(s)
    cheers dean
  4. Re: new audi A6/sd card map update
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    Or if your car can do it, have CarPlay activated, then you can use Waze and you're free from Audi's clutches! :-)
    Audi A6 Avant 2019 Black Edition, C8, 3.0TFSI S Tronic. Tech Pack, Parking Pack, Tow Bar, Tour pack.
  5. Re: new audi A6/sd card map update
    Oct 2015
    Banbridge
    10 Post(s)
    thanks Gav how would i know if i can have car play activated (A6 newbie sorry)
    thanks
  6. Re: new audi A6/sd card map update
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    I believe you need to have MMI MIB2 hardware to start with, which I think started with the face lift model. So if that's the case, then you should be good to go. You can certainly ask if it's possible. I contacted an independent chap who did the firmware update and also enabled CarPlay for £140, job done. Curiously Audi didn't want to know and said it couldn't be done when I asked!
    I used VagCarCoding, he has an instagram page and his WWW site is VAG Car Coding - Coding, Diagnostic & Retrofit Services for VAG Vehicles, he certainly knows his stuff!! :-)
  7. Re: new audi A6/sd card map update
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by gav28uk View Post
    You have the Tech Pack so adding CarPlay is fairly straightforward. Audi never offered Carplay with RMC equipped cars - that the OP has - so adding it is a lot more involved (think it involves hardware as well as changes to the software)
  8. Re: new audi A6/sd card map update
    Oct 2015
    Banbridge
    10 Post(s)
    thanks again Gav
  9. Re: new audi A6/sd card map update
    Oct 2015
    Banbridge
    10 Post(s)
    dont think i have Tech pack
    Quote Originally Posted by johnsimcox View Post
  10. Re: new audi A6/sd card map update
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by Kevmc63 View Post
    You are correct you do not have the Tech Pack, you have the RMC system. Gav28uk does have the Tech Pack and his comment regarding a softare update only applies to cars with Tech Pack
  1. Please Help Map Update via SD Card failing
    By DanD3 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 30-10-2022, 11:38 AM
  2. Question MMI Navigation Maps update via SD Card
    By John Norris in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 21-11-2015, 09:11 AM
  3. Update maps via sd card
    By tonye60 in forum A7 - S7
    Last Post: 26-05-2015, 05:06 PM
  4. Sd card update Saad
    By tonye60 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 14-05-2015, 03:51 PM
  5. SD Card Sat Nav Update Cost
    By johnsimcox in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-04-2014, 01:38 PM
