Thread: Clock spring
  1. Clock spring
    Oct 2020
    Maidenhead
    Hi. Im changing the clock spring on a vw passat, the new part has the same part number except the last 2letters are different. Will the car need to be coded or is it a simple out with the old, in with the new. Thanks
  2. Re: Clock spring
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    What year Passat, and what are the two part numbers? On maybe be a later revision of the earlier part, or a different spec for particular usage.
  3. Re: Clock spring
    Oct 2020
    Maidenhead
    Hi. Its a 2011 model passat with cruise control. Original part number is 5K0953569AB, and new part number is 5K0953569AS, vw said this was the latest part number for this car. Thanks
  4. Re: Clock spring
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Sorry, misread original post as was part code right. Looks like the right part .
    I expect you'll have to code module 16 in VCDS or similar. You'll want to get the coding from the original module while it is fitted to make things easier.
  5. Re: Clock spring
    Oct 2020
    Maidenhead
    Ok. Thanks for your help.
  1. B8 clock spring
    By stjrp in forum Passat - B8 Forum - 2015 -
    Last Post: 10-10-2022, 03:21 PM
  2. Help & Advice on Replacing A6 C7 Clock Spring
    By RizlaUK in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-03-2020, 11:18 AM
  3. Airbag Clock Spring Connector
    By Monzta in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-11-2019, 11:22 PM
  4. clock spring fault a6 c7
    By chris.d in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-10-2019, 01:41 PM
  5. Centering/Aligning Clock Spring
    By Skezza in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2016, 03:36 PM
