Thread: 2007 Jetta is it 1.9 or 2.0?
  1. 2007 Jetta is it 1.9 or 2.0?
    Sep 2020
    Estonia
    First post here! Hoping for a helping hand!
    Im helping a friend sort some oil leaks on her 2007 Jetta Tdi.
    The oil leak is coming from a joint between two parts of the tandem pump body.
    No problem....except I cant be sure Im buying the correct gasket set(unless they are all the same!?)
    There is no part number on the pump, except the LUK logo.
    From the casting number on the head I can see its an 8 valve head.
    So is it a 1.9 or a 2.0?
    The VIN is WVWZZZ1KZ7M........
    Any help gratefully received
  2. Re: 2007 Jetta is it 1.9 or 2.0?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    That's 2.0. There should be an engine code like BKD on the passenger door pillar sticker that will help you get correct parts.
  3. Re: 2007 Jetta is it 1.9 or 2.0?
    Sep 2020
    Estonia
    Thanks! The cars not with me but I could ask the owner to see if the sticker is there.
    The head had the casting number 038103373R if that helps?
  4. Re: 2007 Jetta is it 1.9 or 2.0?
    134 Post(s)
    2025 Post(s)
    If you don’t give us the full VIN, how can a pro with trade systems tell you what it is?
  5. Re: 2007 Jetta is it 1.9 or 2.0?
    Sep 2020
    Estonia
    Sorry squire I thought Id given enough of the code.
    The full VIN is WVWZZZ1KZ7M131841
    If you can help, thanks!
  1. Volkswagen Jetta 2007 Jetta 2.0 TDI 140BHP Knackered Turbo?
    By VolksPolo in forum VCDS - General Questions
    Last Post: 10-11-2017, 02:11 PM
  2. Please Help Engine problems with 2007 Jetta
    By belfastmark in forum Jetta MK3 - 2005 - 2013
    Last Post: 09-04-2013, 04:49 PM
  3. 2007 TDI Jetta - Transmission noises
    By Richnan in forum Jetta MK3 - 2005 - 2013
    Last Post: 13-06-2008, 11:28 PM
  4. 2007 Jetta ?
    By fusemender in forum Jetta MK3 - 2005 - 2013
    Last Post: 30-06-2007, 12:48 PM
  5. 2007 Jetta Ipod Help
    By stevenmhopper in forum Jetta MK3 - 2005 - 2013
    Last Post: 02-03-2007, 09:36 AM
