Thread: DIY Brake Change Query
  1. Question DIY Brake Change Query
    Sep 2020
    dURHAM
    Hi All,
    I'm writing in relation to my 2006 3.0 A6 Allroad. Time has come to change the rear discs and pads. I've done this job countless times on other vehicles and am OK with the release of the EPB (I have VAGCOM) etc. but am hoping that someone can clarify the CORRECT procedure for this job, especially when it comes to pushing the caliper piston back.
    Now, most mechanics I speak to simply say, take the cap of the brake fluid reservoir and push the piston back, using a screwdriver or appropriate tool. Now ordinarily that's what I'd have expected although when I last referred to a well know car repair manual (all be it for a different make/model) it stated that when pushing the piston back in it was ESSENTIAL that the hose be clamped and the bleed nipple opened. It was stated that this was to ensure no seals were 'flipped' by the back-flow of fluid and so that none of the contaminated fluid from the caliper found it's way back into the system which could cause issues/damage to sensitive ABS components.
    Can ANYONE clarify what is the correct procedure as it's driving me nuts not being able to find a definitive answer to this one?
    Thanks,
    Alex
  2. Re: DIY Brake Change Query
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    The general VAG procedure is to ensure that fluid reservoir is not so full that fluid "returned" from pressing caliper back will cause overspill - so full expectation that lines will be open. Some / many lines are not just rubber, they have a braided structure and will be damaged if clamped.
  3. Re: DIY Brake Change Query
    Jul 2008
    Lisburn
    16 Post(s)
    wasnt a french car by any chance was it?
    regardless there is no pushing back of calipers releasing the epb will do that - you do need to calibrate them afterwards of course.
    I used OBDeleven and had no issues.
    Stewart
    1986 coupe quattro (kv)
  4. Re: DIY Brake Change Query
    Jul 2013
    76 Post(s)
    Dan
    2009/2010 2.0 TDIe SE
  1. Oil change query
    By JSRed in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 28-01-2018, 05:35 PM
  2. Another headlight bulb change query
    By Akash in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-02-2012, 12:48 AM
  3. Question Anniversary brake query
    By tommy_g in forum Golf MK4 - 1999 - 2004
    Last Post: 18-04-2010, 04:40 PM
  4. Brake fluid cap query?
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-06-2008, 08:16 PM
  5. Brake Discs and Pads query
    By nirajb_uk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-03-2008, 11:20 AM
