Thread: 2008 b6 passat 2.0 tdi bkp Engine ecu swap
  1. 2008 b6 passat 2.0 tdi bkp Engine ecu swap
    Sep 2020
    ANGLESEY
    Hi all thinking i need to replace engine ecu on my 2008 b6 passat 2.0 tdi bkp can i use vag com to do the swap with used ecu same part numbers
    i bought the car with none starting problem had clutch peddle sensor problem sorted that all working and fault lights are now out . has p0227 fault glow plug light on and engine warning on start up i have changed pedal but no change car starts well but stinks like egr not working it is getting power to 2 pin 2 on plug
    not sure if i have put this i the right place
  2. Re: 2008 b6 passat 2.0 tdi bkp Engine ecu swap
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
  1. Please Help Oil Leak On Passat 2008 2ltr TDI Engine Code BKP - any suggestions?
    By cssvwpassat08 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-09-2019, 11:15 PM
  2. Engine Misfire - Passat 2008 3.2 V6
    By ronnie136 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-09-2016, 07:56 PM
  3. engine swap passat 170 bmr
    By toddy2008 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-03-2010, 09:13 PM
  4. Please Help Passat Headlight swap, is it posible to swap early / late over?
    By scotlandstu in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2009, 11:26 AM
  5. Passat Engine Swap/Oil Leak?
    By kieren12345 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-08-2007, 08:27 PM
