Thread: 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
Results 1 to 10 of 10
  1. 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
    Sep 2020
    Essex, UK
    Hi all,
    I'm having problems with my 2007 Passat 2.0TDi DSG.
    The car is not moving - PRNDS all lit and flashing.
    Parking brake malfunction, PAS light, Traction control, Engine light.... you name it.
    I also get an occasion oil pressure light when cranking, and "engine malfunction".
    Error codes show:
    • p0864 TCM communication Range / Performance
    • p0600 Serial link communication
    I have checked the main ECU which does show a few signs of rusting around the edges, but the connections are all dry.
    The car *did* drive fine - nice gearbox changes and no obvious problems (other than a glow plug /starting issue - rectified where the relay had worked loose beneath the battery tray).
    Anyway - current issue is the problem.
    It was raining when so I assume the TCM *may* have got wet.
    I can't confirm this though as I can even find it!
    Most sources I have found show Left Hand Drive models where the TCM is beneath the splash guard inside the left hand side wheel arch.
    My car is UK RHD - and no sign of it there!
    As said, the car isn't even moving now.
    As soon as you put in P or R, then drive engages it jumps out of gear and the lights begin to flash.
    Any help VERY MUCH appreciated.
    G.
  2. Re: 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Did someone have previous trouble with it and pop it somewhere else maybe? What engine and gearbox code, in case it points to an unusual set up?
  3. Re: 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
    Sep 2020
    Essex, UK
    PASSAT SE TDI 140 AUTO (6 speed)
    2.0 TDI 103KW / 1968 cc
    Wont even start now.
    No glow plug light when ignition is turned on and occasional message to "move shifter to...." [what I assume is P or N?]
    I have also tried another glow plug relay and still the same.
  4. Re: 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Is there a sticker that that has engine code something like BKP on the left, front door pillar? Also shows on the vehicle info sticker in service book and / or boot along with a gearbox code like HXX, KXX, etc?
  5. Re: 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
    Sep 2020
    Essex, UK
    ah, I understand.... sure; Does this hep from the service book?
    3C2146 PASSAT
    KCU LA7T UP
    COMFO 103 KW
    TDI A6F BKP-
  6. Re: 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Still looks like it should be in that left hand wheel arch, back towards cabin. No sign of anything been removed?
  7. Re: 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
    Sep 2020
    Essex, UK
    No nothing at all there. As you say, i expected it to be above the wheel, almost by a pillar!!!
  8. Re: 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by Gallen1976 View Post
    Spare wheel well for the white sticker or nearby under the carpet usually - I would anticipate it being a BKP being a 140PS 2 litre
    Edit: which it is reading your earlier post!
    Gearbox likely to be a JPQ (mine is 2007 and 6 speed wet clutch DSG).
    Mad Mitch
  9. Re: 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
    Sep 2020
    Essex, UK
    Thank you!!!
  10. Re: 2007 Passat 2.0TDi DSG - Transmission Control Module (TCM) location?
    Jan 2012
    10 Post(s)
    88 Post(s)
    Thank you!!!
    Full list of option codes from sticker here:
    Equipment codes list - izzo @ google
    KCU is your gearbox
    BKP is your engine
    LA7T is your United Grey paint code
    Mad Mitch
  1. Please Help Location of engine control module
    By squarewheels in forum Golf MK5 - 2004 - 2009
    Last Post: 13-05-2011, 10:55 AM
  2. Please Help TCM Transmission Control Module location B7 Avant?
    By SherkinAuto in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-09-2009, 10:27 PM
  3. Question Airbag control module location
    By Foogy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-02-2009, 08:32 PM
  4. Transmission Control Module
    By Crockett in forum Golf MK4 - 1999 - 2004
    Last Post: 25-02-2008, 08:33 PM
  5. Transmission control module
    By recruiter111 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-01-2008, 01:35 PM
