Thread: Cam belt and water pump change completed
  1. Cam belt and water pump change completed
    Jul 2007
    somerset
    8 Post(s)
    After spending a fair bit of money having an oil leak and water leak fixed at my local Indi, it was time to also do the cam belt and water pump on my 1.8T cab. I got the parts from TPS as I have a trade account there, just over £100 for every thing. Decided to fit the better mechanical pulley tensioner and ditch the hydraulic tensioner damper. All went well, apart from removing the old pump, which it seems did not want to part company with the block. Anyway, all done and good, the only hassle I had was 3 sheared off screws from the inner wheel arch liner that go into the bumper, even though they are only going into plastic, they had rusted enough to shear straight off without too much torque. Just need to get some new ones tomorrow and it’s all finished.
  2. Re: Cam belt and water pump change completed
    131 Post(s)
    1973 Post(s)
    The sort of stupid problem that can cost you an hour on top of what you had quoted the customer and how do you explain it?
  3. Re: Cam belt and water pump change completed
    Jul 2007
    somerset
    8 Post(s)
    Yes, they were chasing their tail, everything plastic they touched broke. Ended up replacing thermostat, flange at back of engine, lots of pipes and connectors, cam seal vvt gasket associated pipes to do with crankcase ventilation system, new one way valve etc etc.
  4. Re: Cam belt and water pump change completed
    131 Post(s)
    1973 Post(s)
    Been there, done that, got the T shirts and seen the film... the recyclable plastics used on modern cars seem to self recylyle before their time, the ones used on 50's to early 70's Beetles (it all went downhill with the 1303) when I started would still be there after a direct hit with a nuclear bomb.
  1. Cam Belt Change Mystery & Water Pump Conundrum
    By topgazza in forum Golf MK7 - 2013 - 2019
    Last Post: 02-02-2018, 03:26 PM
  2. DSG filter, oil, timing belt and water pump change
    By PajeroGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 07-02-2016, 10:21 PM
  3. Question 2004 A3 Cam belt and water pump change. How much? And where?
    By neuroguy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-06-2013, 01:21 PM
  4. cam belt change,should i have the water pump changed ?
    By boycey19690 in forum Golf MK5 - 2004 - 2009
    Last Post: 10-04-2011, 09:38 AM
  5. How to change water pump belt
    By mm707 in forum Golf MK3 - 1993 - 1999
    Last Post: 18-07-2009, 06:22 PM
