Thread: Manual Gearbox Oil change
  1. Manual Gearbox Oil change
    Jan 2016
    Manchester
    Hi all,
    Me again, with yet another question!
    So I’ve had a search, and skimmed through approx 11 pages to try and find this info to no avail.
    I have 2.0TDI (BKD) with 6 Speed Manual Box (GNE).
    Does anyone know the process for changing the oul on the gearbox?
    I know on the Mk5 Platform it was changed slightly where you can’t use the usual “fill plug” on the side of the box and to put the oil in through somewhere else, reverse light sensor?
    But is there a process for removing air locks etc to ensure all the oil (or most) is drained from the box?
    Cheers,
    Kyle
  2. Re: Manual Gearbox Oil change
    134 Post(s)
    2024 Post(s)
    Very straightforward, get it hot, drop the oil (there are two designs of drain plug, 17mm hex and tamperproof Torx) and leave to drain overnight if possible. Remove the filler plug on the side and fill after replacing the drain plug!) and fill to the level, the car must be level and it is self venting. It is a 02Q box which is a development of the 02M so very straightforward
  3. Re: Manual Gearbox Oil change
    Jan 2016
    Manchester
    Hi Crasher,
    Thanks very much for that!
    That is exactly what I wanted to hear haha! It’s just the traditional method of changing the oil!
    Don’t suppose you happen to know the fill quantities do you?
    Cheers,
    Kyle
  1. Question Manual gearbox oil change
    By didkobandita in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-01-2018, 10:09 AM
  2. Question Gearbox oil change Audi B7 manual
    By mariothag in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-08-2012, 08:04 PM
  3. Manual Gearbox Oil Change
    By Northsea in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-09-2011, 09:51 PM
  4. Gearbox Oil Change 5-spd manual
    By ike in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-05-2010, 08:23 PM
  5. Question can you change the oil in a manual gearbox?
    By N47HAN in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-01-2009, 09:46 AM
