Thread: Air Suspension - Boot Button not working?
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Air Suspension - Boot Button not working?
    Aug 2020
    10 Post(s)
    Thanks for all the messages of help.
    It has started working but I’m pretty sure I’ve not done anything different! I’ll keep my eye on it.
  2. Re: Air Suspension - Boot Button not working?
    Jun 2025
    Enfield
    Quote Originally Posted by ckq7 View Post
    Hi All,
    First post for me, picked up a Q7 yesterday and very impressed with it.
    It has air-suspension and I've found the button in the boot doesn't work to lower the boot. Occasionally it flashes and other times it doesn't even light up. I understand the doors etc. have to be closed which they were. Had there been a pressure issue I think it should flash but most times it doesn't even light up?
    It works fine when engine running, car lowers/rises no problem to get to desired setting.
    Any ideas? Is this normal, am I using it correctly? Can't see anything in the manual to suggest otherwise.
    Having read the manual, the lowest mode it will work on is dynamic. I am viewing one and I tried to lower rear while in the off road mode and it didn’t work. If you google air suspension manual q7 you should be able to view which has a flow chart.
  1. AC Button not lighting up. Toggle button not working.
    By Dar123 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 08-02-2016, 11:53 PM
  2. AC Button not lighting up. Toggle button not working.
    Last Post: 06-02-2016, 08:33 PM
  3. Boot button
    By sandis in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-10-2013, 08:46 AM
  4. Boot release switch not working but the key fob button does work...
    By StratosHF in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-07-2012, 08:19 PM
  5. Question A3 2004 Boot / Boot button on Key fob
    By youngybear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-02-2010, 09:52 AM
