Thread: Passat b8 clutch smoke. Lots of smoke.
Results 1 to 8 of 8
  1. Passat b8 clutch smoke. Lots of smoke.
    Aug 2020
    Uk
    Yesterday we drove from Portsmouth to Cornwall. Roughly a 4.5 hour drive. 3 hours into the journey driving up a steep hill, changing down from 6th to 5th the car lost power. More throttle was applied with no increase in power. The clutch pedal seams to have got stuck and it would not change gear. The high revving seriously smoked the clutch. We stopped for 20 minutes then took a short test drive and the car was fine. We continued our journey with no issues.
    I've read various post online about sticking clutch but none for the B8
    Has anyone experienced this on a 2015 B8, approx. 80k miles? Any thoughts on the problem?
  2. Re: Passat b8 clutch smoke. Lots of smoke.
    131 Post(s)
    1978 Post(s)
    If it smoked that badly (it is an appalling stench) then the system will be life limited now, which engine code?
  3. Re: Passat b8 clutch smoke. Lots of smoke.
    Aug 2020
    Uk
    Hi Crasher.
    There is no ODB code.
  4. Re: Passat b8 clutch smoke. Lots of smoke.
    131 Post(s)
    1978 Post(s)
    Not fault code, engine type code.
  5. Re: Passat b8 clutch smoke. Lots of smoke.
    Aug 2020
    Uk
    Hi Crasher.
  6. Re: Passat b8 clutch smoke. Lots of smoke.
    Mar 2016
    Minervois, France
    54 Post(s)
    Hello. He wants the code of your engine, which engine you have. Nothing to do with OBD.
    And next time your engine "loses power" I suggest you lift off the gas pedal instead of tramping on it and spinning the clutch until it smokes.
    Maybe you would find a course on basic engine mechanics quite useful.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
    1 1 0
  7. Re: Passat b8 clutch smoke. Lots of smoke.
    131 Post(s)
    1978 Post(s)
    Quote Originally Posted by FrenchAudi View Post
    ouch...
  8. Re: Passat b8 clutch smoke. Lots of smoke.
    Mar 2016
    Minervois, France
    54 Post(s)
    ouch...
    My apologies Bumpyroad if my reply sounded sarcastic; it was meant to be helpful, as you evidently were not able to identify the symptoms of a slipping clutch.
  1. Question lots of oil smoke at startup?
    By tonyar in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-03-2010, 04:09 PM
  2. Lots of smoke on startup?
    By Yellow Peril in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 02-01-2010, 09:17 PM
  3. Lots of smoke.
    By vinny1111 in forum Golf MK3 - 1993 - 1999
    Last Post: 13-08-2009, 02:20 PM
  4. passat 1996 lots off smoke when started
    By jill300268 in forum Early Passat Forum - Pre 97
    Last Post: 16-01-2008, 12:31 AM
  5. No Power, lots of smoke
    By makil6 in forum Archive posts
    Last Post: 15-01-2008, 07:00 PM
