Thread: Where do i stick it ?
Results 1 to 10 of 11
  1. Question Where do i stick it ?
    Sep 2007
    Hi a quick question that wont be to hard to answer . I have ordered myself a code reader , and need to know where the port is ? Or are there more than one ? Its an 04 a4 1.8t cab . Many thanks Papalion .
  2. Re: Where do i stick it ?
    Dec 2006
    It under the dash to the right...
    i will post a pic... below
    The easy thing to do is open the drivers door, and get your head in the footwell and look up..
    Rick
  3. Re: Where do i stick it ?
    Sep 2007
    hi thanks for that ill be under there first thing .
    PAPALION
  4. Re: Where do i stick it ?
    Birmingham
    Hi Papalion/RickT, just reading through all the posts about the connection cables and software available to diagnose issues. I'm am totally conmfused, how do you go about identifying what cable and freeware to use? I have an A4 2.0 Sport 02 model (B6 I think) - can you help? I have found some sites on ebay offering all sorts of different cables and looked at the ross-tech site and got more confused!
  5. Re: Where do i stick it ?
    Oct 2005
    There are plenty of vendors around and I agree it's an overwhelming subject to get to grips with.
    Have a look in our VAG-COM section for some ideas and when you're ready to purchase I can recommend eshrules (a member here).
    He has a section in the forum discounts subforum.
    Welcome to VWAF too
  6. Re: Where do i stick it ?
    Dec 2006
    i used the below ebay seller to get mine a few years ago..
    http://search.stores.ebay.com/alpha-...Q20usbQQsofpZ0
    have a look at the Ross Tech website and you will be able to see the type you need.
    If i remember right... you need a KKl ODB2 - and i use VAG-COM version 4.9
    Rick
  7. Talking Re: Where do i stick it ?
    Birmingham
    Thanks RickT - that's the conclusion I came to - after much mumbling and searching
  8. Re: Where do i stick it ?
    Dec 2006
    Quote Originally Posted by lweston View Post
    Good stuff... its pretty easy to set up if it works first time...
    if using XP you should have no issues..
    Rick
  9. Re: Where do i stick it ?
    Canada
    I run a registered version 409.1 with 3rd party cable on Vista with no issues.
  10. Re: Where do i stick it ?
    Dec 2006
    Quote Originally Posted by onzarob View Post
    Cheers for the testing Rob.. i was thinking about the older app's and vista..
    Rick
  1. B5 replacing the gear stick gaitor?
    By jedi172 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2007, 04:22 PM
  2. Audi 2.8 auto dip stick
    By roogy in forum Chat - Anything with wheels
    Last Post: 27-04-2007, 09:05 PM
  3. A3 removal of Gear stick 1.8 20vT 97 p
    By chocoboy in forum Audi A3 - Archive Topics
    Last Post: 26-02-2007, 01:23 PM
  4. Rear wiper seems to stick mid screen
    By AudiwantisanS3 in forum Archive posts
    Last Post: 09-02-2007, 08:23 PM
  5. Replies: 1
    Last Post: 05-01-2007, 07:19 PM
