Thread: GT TDi Not Starting CBAB
  1. GT TDi Not Starting CBAB
    Aug 2020
    Norfolk
    Hi There
    I have a 2009 GT TDI 2.0 with the CBAB engine. It would have a very intermitant fault where it would turn over on the starter and not fire. After 2 or 3 tries it would start straight away and run fine. However this weekend its just decided not to start at all. The fault codes flagged up are unrelated to the engine but they're the same ones each time. They would erase and only come up on a non start - this time however they're not erasing
    It has the symptoms of a crank sensor but no fault codes suggesting so. I have seen threads where people have had similar issues, changed the crank and cam sensors and it made no difference but no one seems to of reported back if they got it sorted and what the fault was.
    So I was wondering if anyone has had the same issue and had it resolved? If so what was the fix?
    Many thanks in advance. This has been quite a head scratcher
  2. Re: GT TDi Not Starting CBAB
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Would be usefull if you said what the fault codes were.
    I take it that the engine is actually turning over but not fireing.
    Have you tried a squirt of easy start or brake cleaner in the inlet to see oif it will fire.
    A common problem is the throttle valve getting stuck shut due to gung from the EGR.
  3. Re: GT TDi Not Starting CBAB
    Aug 2020
    Norfolk
    Quote Originally Posted by philipharmes View Post
    Yes the engine is turning over but just not firing. The mk5 Golf had a low crank speed sensor where if it was less than 270 RPM or something it wouldnt allow the engine to fire. I didnt know if the mk6 had the same system?
    I only a have list with the system name and status. These are
    Brakes = Fault
    HVAC = Fault
    Central electrics = Fault
    Dash Board = Fault
    Gateway = Fault
    Steering Assistance = Fault
    I will investigate the gunged throttle valve - now you mentioned it I vaguely remember hearing it before
    Thanks for your reply
  4. Re: GT TDi Not Starting CBAB
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by suomy View Post
    Brakes = Fault
    HVAC = Fault
    Dash Board = Fault
    Gateway = Fault
    Those aren't error codes?
    You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  5. Re: GT TDi Not Starting CBAB
    2009 Post(s)
    The throttle valve has a feedback position sensor so a proper code read will tell you if it is stuck and when they are closed the engine turns over faster as if it has no compression... as it doesn’t.
  6. Re: GT TDi Not Starting CBAB
    Aug 2020
    Norfolk
    Just a heads in case anyone else has a similar issue as it has now been resolved.
    I was able to turn the engine over without depressing the clutch pedal making me think it could of been the clutch pedal switch. Not the case. It turned out to be a faulty relay casuing a voltage drop which prevented sufficient communication between the ECU and other systems hence the random unrelated fault codes. New relay fitted and the car now starts first time every time and no more fault codes
  1. CBAB oil pump hex drive
    By DirtyDiesel_VAG in forum Golf MK6 - 2009 - 2013
    Last Post: 06-04-2025, 01:12 PM
  2. Question Cbab Turbo failure on 60 plate 113k miles
    By krienkes4 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-05-2018, 08:38 AM
  3. 2.0 Tdi common rail (CBAB)
    By richiek in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-02-2018, 10:31 PM
  4. Cbab no start
    By Audiforlife in forum VCDS - Help Requests
    Last Post: 25-01-2017, 12:32 AM
  5. Clutch, DMF and a CBAB engine
    By furiousgeorge in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-03-2016, 04:03 PM
