Thread: Coolant loss but no leak
  1. Coolant loss but no leak
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I am looking at a neighbours Golf Mk7 2013 diesel engine CRBC. The complaint was that there was a low coolant warning light and and after seeing that the filler tank was empty, he topped it up with Prestone antifreeze. Not G13++. (According to Prestones website, its ok). Anyhow, the engine did not overheat when the warning light came on, but the heater is now blowing warm and cold air, so I guess that's just air in the system.
    I have carried out a pressure test 3 times, 1 Bar, and and pressure drops to zero in about 1 hour, I have looked everywhere and just can find a leak. I expect the coolant is going somewhere internal but cant think what to look at first.
    Any advice would be appreciated.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: Coolant loss but no leak
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by shabazmo View Post
    I have read elsewhere on other VAG forums that some have found unexplained water loss to be due to a leak around the water pump, but the heat of the engine leads to the water evaporating away so no sign obvious sign of a leak.
  3. Re: Coolant loss but no leak
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks John. I carried up the pressure test when cold and paid particular attention to the water pump,area but no sign of water. It has been a few days since I last saw the car so am waiting for further feedback on the water level.
  1. Coolant leak - Culprit is the Coolant inlet valve seal
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-01-2024, 08:48 PM
  2. Replies: 0
    Last Post: 05-07-2020, 12:26 PM
  3. 1.9TDI (BKC) Fuel Pump Leak & Coolant Leak.
    By DannyBoyGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 16-07-2018, 10:51 PM
  4. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  5. Important Loss of coolant, unable to find leak.... HELP!!
    By crazycowell in forum Bora - 1998 - 2005
    Last Post: 21-11-2011, 01:45 PM
