Thread: knee Airbag igniter fault - short to ground
Results 11 to 20 of 21
  1. Re: knee Airbag igniter fault - short to ground
    Feb 2022
    Dublin
    I'm having the same problem. Did you get to the bottom of it by any chance? A local garage also suggested i replace the airbag module and they'll remove the CP and code it, but i'm afraid the code will still be there.
  2. Re: knee Airbag igniter fault - short to ground
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    I wouldn't be surprised if it wasn't water ingress into the wiring or a connector.
    Get the floor carpet loosened both sides ( passenger & driver ) & get your hand in under the foam which is under the carpet.
    Check to see if any wetness under there.
  3. Re: knee Airbag igniter fault - short to ground
    Feb 2022
    Dublin
    Its no water. My car is garaged
  4. Re: knee Airbag igniter fault - short to ground
    May 2022
    Lyon
    Hello
    I have the same problem. Are you by any chance the cause of this problem? I would really appreciate any help
    thanks.
  5. Re: knee Airbag igniter fault - short to ground
    Jul 2022
    uk
    Guys did you found resolution to the problem, i got the same issue?
  6. Re: knee Airbag igniter fault - short to ground
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Quote Originally Posted by S shah View Post
    What fault code are you seeing, with what reader?
  7. Re: knee Airbag igniter fault - short to ground
    #17
    Jul 2022
    uk
    B100911 Driver side, rear seat belt tension igniter Short-circui
  8. Re: knee Airbag igniter fault - short to ground
    #18
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    On what car?
    There may be some yellow plugs at the bottom of the pillar behind the door. With battery disconnected (to avoid embarrassing deployment of airbags) unplug them, then battery back on and scan to see if fault changes to "open circuit / resistance high". If so it'll be a problem in the wires from plug to igniter.
  9. Re: knee Airbag igniter fault - short to ground
    #19
    Jul 2022
    uk
    Quote Originally Posted by VAG-Abound View Post
    On what car?
    The problem is there is no wiring to the seat belt as its for american market only. so the car is giving alarm for system which is not there in the car.
  10. Re: knee Airbag igniter fault - short to ground
    #20
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Several threads on phantom shorts to non-existent airbag circuits have been inconclusive, but I think where it is fixed people usually decide that is water or age damage to the airbag controller.
  1. Question Airbag short to ground
    By Martynas26 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-06-2015, 05:47 PM
  2. Airbag Igniter Fault
    By Boy in forum VCDS - Help Requests
    Last Post: 14-05-2014, 11:32 PM
  3. Please Help 00588 - Airbag Igniter; Driver Side (n95) fault
    By Cylon2007 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-09-2013, 07:33 PM
  4. Please Help Airbag Igniter Fault
    By Boy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-05-2012, 06:48 PM
  5. Please Help Fault code 17903 - Switch-Over Valve for EGR Cooler (N345): Open or Short to Ground
    By Michael Blythe in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-01-2012, 05:29 PM
