Thread: Rumble/ noisy clutch only when pulling away in 1st
  1. Rumble/ noisy clutch only when pulling away in 1st
    Sep 2016
    Nairn
    VW CC 2.0 tdi 33,000 miles.
    Noise appears just before bite point upon lifting up clutch when pulling away, can be felt through the pedal until I’m over a few mph then the engine and road noise drowns it out/ mixes up the feeling coming through the pedal.
    No vibrations or noise when driving other than what sounds like tyre roar from front left of car, could this be a wheel bearing?
    Last clue when driving and coasting in 4th gear if I rest my hand on the gear knob I can feel a change of vibration on deceleration only, not when accelerating.
    Gears changes are all smooth and quiet, I have a years warranty from the dealer, anyone have any clues with such low mileage I’m amazed I have a problem.
    Oh also feels somewhat like a have left the handbrake on when I initially begin to pull away, once the car has moved a foot it’s fine, I know the handbrake is disengaged it caught me out a few times.
  2. Rumble/ noisy clutch only when pulling away in 1st
    Sep 2016
    Nairn
  3. Re: Rumble/ noisy clutch only when pulling away in 1st
    131 Post(s)
    1976 Post(s)
    The resistance pulling away is the hill hold assist, quite normal. Without feeling it the clutch vibe sounds normal as well, for a fuel of the Devil engine.
  4. Re: Rumble/ noisy clutch only when pulling away in 1st
    Sep 2016
    Nairn
    It’s a different feeling to the hill hold, felt more like a lot of clutch slip when I was expecting the bite point to pull up more slack.
  5. Re: Rumble/ noisy clutch only when pulling away in 1st
    131 Post(s)
    1976 Post(s)
    It could be the DMF and clutch on their way out.
  6. Re: Rumble/ noisy clutch only when pulling away in 1st
    Sep 2016
    Nairn
    Just got the car back from my local trusted garage, owner test drove the car strewing the clutch and couldn’t link any noises to dmf failure, also wasn’t put off with the extra vibrations on pull off or increased noise. He did notice a higher pitched whine on acceleration which I asked him to listen out for, he concluded it could be from the engine somewhere, vacuum leak maybe, I thought it sounded more mechanical/drivetrain than engine noise.
    Anyway long story short car is sound for now, apart from the headlight motor giving me warning lights on the days and disabling afs (bend lighting). Hoping the warranty cover faulty headlights..
  1. £1000 to investigate clutch judder when pulling away
    By Mike41 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-08-2016, 10:19 PM
  2. Question Golf mk6 1.6tdi - Clutch judder when pulling away. Also between 1st & 2nd.
    By ayeready in forum Golf MK6 - 2009 - 2013
    Last Post: 16-12-2014, 08:03 PM
  3. Rumble coming through clutch pedal and back of engine when changing gears
    By simonrk57 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-02-2013, 05:45 PM
  4. clutch rumble noise ?
    By tdi alastair in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-05-2010, 11:07 PM
  5. Clutch noise when pulling away
    By mrobson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-07-2009, 02:20 PM
