Thread: VW Touran 2016 tailgate / boot lock issue
Results 1 to 8 of 8
  1. VW Touran 2016 tailgate / boot lock issue
    Aug 2020
    Budapest, Hungary
    We have a 2016 Touran, Europe modell. I had an issue half a year ago, that the tailgate lock did not open, only for a couple of attempts on pressing the button on the key. They repaired as a warranty repair, and it was working fine for a while, but now it's acting up again.
    Issues:
    • Even if the car has been opened, e.g. the car stopped and all the doors are open, you cannot open the trunk
    • Using the car open button (the one that opens all the locks) doesn't work at all.
    • You have to keep pressing the trunk lock button for couple of seconds until it clicks and you can open the door
    • And even then sometimes it just opens "halfway" and you cannot fully open the tailgate
    • Once you shut the tailgate, it locks and you have to do the trick with the tailgate button again to get it opened
    The car is not under warranty anymore, so I bought a new tailgate lock assembly and replaced the existing one.
    The issue is still the same.
    Using a Bluetooth ODB2 scanner and a free iOS app Car Scanner, the only trouble code that the system gave was:
    09. Onboard supply control unit (this the term that the app used)
    203016
    Status: Test failed, Confirmed
    I could not find anything on the internet for this, I'm not even sure if this is a real error code or not...
    Any ideas?
    Thanks!
  2. Re: VW Touran 2016 tailgate / boot lock issue
    Apr 2022
    Prague
    Hi @bbence84,
    Have you somehow solved this problem? I have a similar situation
  3. Re: VW Touran 2016 tailgate / boot lock issue
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Quote Originally Posted by Throb View Post
    Hi @bbence84,
    How similar? Do you have a fault code scan?
  4. Re: VW Touran 2016 tailgate / boot lock issue
    Apr 2022
    Prague
    @VAG-Abound,
    I didn't take a screenshot, but the error code (203016) and boot latch symptoms are similar to topicstarter.
  5. Re: VW Touran 2016 tailgate / boot lock issue
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Looking elsewhere that code means problems with the boot release switch in the handle. Is that the problem you have: the car is unlocked but you can't release the boot by clicking the button in the "handle"?
    There's pictures here of how I fixed a problem with ours, although I didn't scan it to see what code was showing (if any): Touran: Tailgate won't open from remote, also rear wiper and spray won't work
  6. Re: VW Touran 2016 tailgate / boot lock issue
    Apr 2022
    Prague
    Thank you @VAG-Abound, but my Touran is on MQB platform so the boot release has different design/scheme.
    And yes, my problem is with the boot release switch in the handle and about 6 months I have to open the boot using middle button on keys.
  7. Re: VW Touran 2016 tailgate / boot lock issue
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    It is a similar problem then I think.
    The actual boot release is always from the central control unit. If the remote button can release the boot then it means the actual lock mechanism works.
    if the boot physical switch doesn't work then it means the central control unit is not detecting the switch being pressed. That's usually because either the switch is stuck (so it never moves to create an on / off) or the wiring / switch is electrically broken.
    Do you feel a soft click when you try to open the boot? if not then it may be stuck inwards.
  8. Re: VW Touran 2016 tailgate / boot lock issue
    Apr 2022
    Prague
    Solved by replacing button (code 3V0827566) with a new one. And yes, @VAG-Abound, a new button has this soft click, the old - no. Thanks
  1. Touran tailgate lock
    By viperex in forum Touran - Sharan - Caravelle
    Last Post: 28-08-2019, 07:38 PM
  2. Question Replacing Boot Lid/Tailgate on 3dr A3 8P - Lock/Central Locking
    By Tec2tec in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-01-2019, 11:26 AM
  3. Please Help Boot Tailgate lock will not open
    By mollypoppy in forum Arosa
    Last Post: 16-07-2008, 04:45 PM
  4. help touran tailgate will not lock
    By jay13032591 in forum Touran - Sharan - Caravelle
    Last Post: 29-10-2007, 10:49 PM
  5. 96 passat boot tailgate lock
    By dyson in forum Passat - Archive Topics
    Last Post: 01-01-2007, 11:34 PM
