Thread: Multifunction Steering Wheel Retrofit
  1. Multifunction Steering Wheel Retrofit
    Near Blackpool
    48 Post(s)
    Hello, just after a bit of clarity. Bought a multifunction steering wheel part 8P0419019DT
    The guide I’m following says the 3 wires should be:
    Pin 1 blue (LIN)
    Pin 2 red(+12)
    Pin 3 black
    In my case pins are
    Pin 1 black
    Pin 2 yellow
    Pin 3 red
    I would assume that red and black are obviously power and yellow is lin but didn’t want to connect it wrong. Is there anyone with access to a wiring diagram for this wheel?
    Thanks in advance.
  2. Re: Multifunction Steering Wheel Retrofit
    Near Blackpool
    48 Post(s)
    So the wiring guide I followed was right but now I’m having another issue which I’m hoping someone can help me with.
    Original steering module - 1K0953549AH mid line
    I’ve replaced with - 1K0953549AG high line
    I’ve recalibrated the steering angle sensor etc and that’s all come back working again. You have to clear the previous values stored using a login code and adaptation channel 60 (found a guide in VCDS wiki). No faults showing BUT the horn doesn’t work anymore. I’ve tried a different steering module 1K0953549AS, that one caused an ignited fault and also horn didn’t work so I went for the AG one.
    The steering wheel buttons light up now constantly which I don’t think they should but they react to the dimmer next to the headlight switch so it’s getting the “lin” messages. Am I missing something? Surely the horns not wired differently with these units?
    Any ideas
  3. Re: Multifunction Steering Wheel Retrofit
    Near Blackpool
    48 Post(s)
    So I’ve reverted back to the original unit whilst I workout what the hell im doing wrong. I think I need a different module.
    If the AH was the factory fitted module is there a way to find out what the high line would have been?
  4. Re: Multifunction Steering Wheel Retrofit
    131 Post(s)
    1973 Post(s)
    I could do with the VIN
  5. Multifunction Steering Wheel Retrofit
    Near Blackpool
    48 Post(s)
    Wauzzz8px
    Last edited by jonathanfenton; 07-08-2020 at 06:22 PM. Reason: Removed vin from internet
  6. Re: Multifunction Steering Wheel Retrofit
    131 Post(s)
    1973 Post(s)
    From the 2006 model year, the AE, AF and AH are all superseded by 8P0 953 549 F no matter which wheel is fitted.
  7. Multifunction Steering Wheel Retrofit
    Near Blackpool
    48 Post(s)
    Thanks a lot for that. I’ve been an idiot and not noticed that the beginning is different. I’ve ordered the one quoted and will try that!
    Thanks again.
  1. Retrofit Multifunction Wheel
    By nizzex in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2016, 11:29 AM
  2. Potential Retrofit - Multifunction Steering Wheel
    By pdlh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-11-2014, 10:37 PM
  3. Flat Bottom Multifunction Steering Wheel Retrofit
    By soslower in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 18-06-2014, 04:31 PM
  4. Multifunction Steering Wheel Retrofit Help
    By vaslam1986 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-05-2013, 08:34 PM
  5. Can I Retrofit a Multifunction Steering Wheel
    By Bilibong in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-04-2008, 10:39 PM
