Thread: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
Results 1 to 10 of 15
  1. 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Jul 2016
    United Kingdom
    Hi all,
    Looking for some help, I have just replaced the timing belt and water pump on a 56 plate 1.9 Tdi Jetta, Locked cam and bottom end off with timing tools, rotated by hand a few times, lock off tools fitted back in perfectly.
    So I put it all back together and got inside the car expecting it to start right up and it just keeps turning over and wont fire up. Any ideas? I'm struggling to think whats going on, I've turned it over again a few times by hand and the tools still fit in properly.
  2. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    131 Post(s)
    1976 Post(s)
    Did you disconnect the fuel filter assembly?
  3. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Crank speed sensor got disconnected somehow?
  4. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Jul 2016
    United Kingdom
    Fuel filter assembly stayed connected only moved it to the side, crank speed sensor OK, really struggling to find an issue I'm starting to wonder if the timing could be off but I don't really see how if its lining up with the tools.
  5. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Do you have VCDS or similar to watch readings as it cranks?
  6. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Jul 2016
    United Kingdom
    I can probably borrow VCDS off a friend tomorrow if I can't get it going, luckily we don't need the car on the road immediately as we have other vehicles but I'm totally confused whats happened I have a haynes manual here and everything looks correct, I have noticed there are two types of crank locking tools for these engines and started to wonder if I've used the right one but I have both tools and the other one doesn't line up with the mark on the bottom pulley.
  7. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Jul 2016
    United Kingdom
    I have VCDS now, what should I be looking for?
  8. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Something like this: Please Help A3 2.0tdi bkd stalled won’t start
    Crank speed in measuring blocks to see if it is non-zero and IIRC around 3000 to get the engine to start. There are other posts on that and I'm just (mis-?)quoting others .
  9. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    131 Post(s)
    1976 Post(s)
    Which crank locking tool did you use?
  10. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Jul 2016
    United Kingdom
    I used the T10100 crank locking tool. Haven't had chance to look at the car today but will check out vcds tomorrow hopefully.
  1. 2006 Jetta 1.9 TDI Warm Start Problem
    By MrXee in forum Jetta MK3 - 2005 - 2013
    Last Post: 19-08-2010, 07:44 PM
  2. Please Help 2006 - Timing Belt change gone wrong !!
    By andy4976 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-02-2010, 08:51 AM
  3. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  4. Question 2006 2.0TDI SPORT Timing belt replacement
    By CNPrior in forum Jetta MK3 - 2005 - 2013
    Last Post: 16-07-2009, 10:51 PM
