Thread: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    134 Post(s)
    1996 Post(s)
    So yours has the oval crank pulley?
  2. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Jul 2016
    United Kingdom
    Yes the pulley is the same as the bottom picture with the arrow to the right. I saw on a youtube video that vw made some with incorrect timing marks but not sure if there is any truth in that and I don't want to just start guessing where the timing goes.
  3. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    134 Post(s)
    1996 Post(s)
    They are not very common so we can eliminate that as the problem. Have you given it a sniff of brake cleaner? And I MEAN JUST a sniff!
  4. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Jul 2016
    United Kingdom
    I don't have any around to try at the moment but ill get some and give it a try and report back.
  5. Re: 2006 (56) 1.9 TDI Jetta Won't start after timing belt kit replacement!
    Jul 2016
    United Kingdom
    Got chance to have another look at the car today and got it running! Turned out the cam just needed a slight adjustment to the left and it fired straight up, just gotta check the torsion values and set it up properly.
  1. 2006 Jetta 1.9 TDI Warm Start Problem
    By MrXee in forum Jetta MK3 - 2005 - 2013
    Last Post: 19-08-2010, 07:44 PM
  2. Please Help 2006 - Timing Belt change gone wrong !!
    By andy4976 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-02-2010, 08:51 AM
  3. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  4. Question 2006 2.0TDI SPORT Timing belt replacement
    By CNPrior in forum Jetta MK3 - 2005 - 2013
    Last Post: 16-07-2009, 10:51 PM
