Thread: Checked horn fuse now ABS, power steering, speedometer and cruise control not working
  1. Checked horn fuse now ABS, power steering, speedometer and cruise control not working
    Jun 2023
    Gold Coast
    Airbag dash light was on so checked fuses before thinking it was the clock spring. After this I now have so many so many dash lights on. Lost speedometer, power steering and cruise control.
    I have ordered an OBD11 to try and clear codes.
    I have also tried resetting ecu by disconnecting battery cables and joining them together to drain charge from all electrical.
    Still trying to determine Air Conditioner fault. I think it maybe a bad sensor that may need replacing.
    I have checked all fuses in both fuse boxes.
    Any help on how to approach ABS, Airbag and AC would be greatly appreciated
  2. Re: Checked horn fuse now ABS, power steering, speedometer and cruise control not working
    Jul 2008
    Lisburn
    16 Post(s)
    on a quick look - lost comms missing messages low voltages.
    I would check your power to no above mentioned control modules- looks to be a bad ground/battery/relay. then you have an airbag to sort out.
    It might help to post this in your vehicles specific forum group.
    Stewart
    1986 coupe quattro (kv)
  1. Question Steering wheel horn not working
    By DieselMonster in forum Scirocco - 2008-
    Last Post: 28-09-2019, 08:33 PM
  2. Question Horn - not fuse, not relay, not clock spring - not working!
    By leeds lad in forum VCDS - Help Requests
    Last Post: 13-07-2017, 02:01 PM
  3. Erratic speedometer reading / cruise control
    By robin_coxie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-08-2013, 08:28 AM
  4. Question steering control module for cruise control
    By doggydoctor in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-07-2012, 11:02 AM
  5. A6 Cruise control not working
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-02-2009, 09:42 PM
