Thread: 2010 A4 2.0 tdi, cranks but wont start
  1. 2010 A4 2.0 tdi, cranks but wont start
    Jul 2020
    Weston Supermare
    Any help would be appreciated,
    Whilst driving I notice glow plug light starts flashing but car still driving fine, switched car off but then when I tried to restart it was a bugger to get started again but eventually restarted, engine would run up for like 2 secs and then cut
    Anyway once started drove home, everything fine but light still flashing, switched off, ran vag.com nothing shows related to this problem
    Tried starting again and first few times engine would fire for 2/3 secs and then cut, now engine just turns over but wont fire at all, tried easy start still no joy - but inlet seems like its pushing air out rather than sucking air in
    What should I try next, thanks in advance
  2. Re: 2010 A4 2.0 tdi, cranks but wont start
    Apr 2018
    N.Ireland
    9 Post(s)
    Could be as easy as a blocked fuel filter, i had similar issue when i bought my car and a filter service fixed it. Further to this check your fuel pressure regulator (low pressure side) for metal filings, if present it could point to high pressure fuel pump being done in. all this considered mine is a 2.7 so not sure if the same problems exist in the 2l
  3. Re: 2010 A4 2.0 tdi, cranks but wont start
    Jul 2020
    Weston Supermare
    Nevermind, not sure what caused it but car ate its timing belt but thank you for helping - I will be rebuilding it :-)
  1. Car Cranks wont start
    By hezim in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-05-2020, 10:07 AM
  2. Please Help 6n2 cranks but wont start
    By mrg123 in forum Polo - Derby - Lupo - Fox
    Last Post: 10-10-2016, 05:52 PM
  3. Replies: 1
    Last Post: 28-07-2016, 08:27 PM
  4. Cranks but wont start 2007 2.0TSFI
    By Killakam78 in forum Leon
    Last Post: 26-12-2014, 10:06 PM
  5. Cranks but won't start
    By thevagcr in forum Golf MK4 - 1999 - 2004
    Last Post: 30-07-2012, 03:24 AM
