Thread: 1st and Reverse gear very hard to shift when car warmed up vw cc passat
  1. 1st and Reverse gear very hard to shift when car warmed up vw cc passat
    Jul 2020
    Bristol UK
    Hi there newbie here.
    I am experiencing gear selector issues with 1st and reverse only with my VW Passat 170 GT Manual 6 speed 2010 but ONLY when its warm.
    If the car is cold I have no issues although the gear stick does seems slightly stiff from when I first got it all the time from left to right when in neutral.
    I have 140k on the clock and I have added 60k of those via motorways mostly.
    At first I noticed the gear selector seemed to be a little stiff but didn't think much of it as it wasn't used must and still isn't at present.
    This has now developed into a issue but only with the lower gears. If I am able to engage a lower gear when the car is hot it selects it and is fine but if it gives resistance I'm not going to force it and never have. I have taken it to a local garage and they greased up the linkage and said it seems ok for no cost and said next step will be costly and involve the gear box - Yikes.
    Any advise would help please.
  2. Re: 1st and Reverse gear very hard to shift when car warmed up vw cc passat
    Aberdeen
    63 Post(s)
    Welcome to the forum. Probably best posting in the vw section to get more replies. Try the golf or Audi a4 section as they will have the same engine too.
  3. Re: 1st and Reverse gear very hard to shift when car warmed up vw cc passat
    135 Post(s)
    2041 Post(s)
    Quote Originally Posted by Scott K View Post
    Try the Audi a4 section as they will have the same engine too.
    mmm, longitudinal and transverse...
  1. Please Help 2.4Q Tiptronic-issue. Hard shift 1-2-1
    By Mariusml in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-12-2015, 08:29 PM
  2. Please Help A4 2.4 SE Auto - no reverse power / hard to reverse
    By stephen heather in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-06-2010, 08:59 PM
  3. Hard to select Reverse & 5th gear
    By the_old_diver in forum Touran - Sharan - Caravelle
    Last Post: 06-12-2009, 10:54 PM
  4. Reverse gear hard to select on 2.5TDi 6 speed
    By dean warren in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-10-2009, 11:06 AM
  5. Question Hard start even after warmed up
    By Sureshd300 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-03-2009, 06:27 PM
