Thread: Adaptive xenons problem
  1. Adaptive xenons problem
    Mar 2013
    Reading
    31 Post(s)
    So, got a strange one a few days back: the car reported "adaptive lights malfunction". It went off and on a few times since then.
    The error picked up by OBD11pro is as following:
    *** Year: 2013
    *** Body type: Avant
    *** Engine: CDUD 180 kW (244 HP) 3.0 l
    *** Mileage: 115773 KM
    55 Headlight Regulation
    *** System description: ....AFS13....
    *** Software number: 4H4907357C*
    *** Software version: 0020
    *** Hardware number: 4H4907357A*
    *** Hardware version: H01
    *** Serial number: 130503-0004-0543**
    *** ODX name: EV_AdvanFrontSyste
    *** ODX version: 005001
    *** Long coding: 1122A633F818E300
    *** Trouble codes:*
    ******* C108313 - Left stationary AFS Open circuit
    *********** static
    *************** Date: 2020-07-04 16:24:46
    *************** Mileage: 115773 km
    *************** Priority: 2
    *************** Malfunction frequency counter: 1
    *************** Unlearning counter: 254
    Sometimes it pops up after clearing the code immediately, sometimes, it does not come up at all.
    Hence, as I had some fun with swapping springs recently, can it be related to this? If not, what's the culprit and where is it located?
    Sent from my mobile...
  2. Re: Adaptive xenons problem
    134 Post(s)
    2022 Post(s)
    Could you PM me the REG or VIN?
  3. Re: Adaptive xenons problem
    134 Post(s)
    2022 Post(s)
    I think that is the H7 “low beam lighting” bulb, I will check at work.
  4. Re: Adaptive xenons problem
    Buckinghamshire
    Quote Originally Posted by Johnny31 View Post
    I had this error pop up a while ago on my car - it was just the near-side cornering bulb that needed replacing. Like you it was intermittent, but pretty much always came on when I made a slow left turn, i.e. when the cornering light would've come on. Was a fairly simply bulb to swap out.
    Neil.
    Current: 2013 A6 2.0 S-line manual, moonlight blue, tech pack, adaptive xenons, heated front seats, storage and lighting pack
    Previous: 2007 A6 2.0 TDI SE
  5. Re: Adaptive xenons problem
    Mar 2013
    Reading
    31 Post(s)
    Quote Originally Posted by neil s View Post
    Neil.
    Forgot to reply - Neil, you were on the money - it was the exact same thing...
    Sent from my KB2003 using Tapatalk
  1. 2008 adaptive bi xenon problem
    By dannyboygti in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-06-2015, 11:15 PM
  2. Xenons problem
    By badfelafel in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-11-2014, 10:23 PM
  3. Adaptive LED Bi Xenons
    By MrHSingh in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-07-2014, 08:50 PM
  4. Curb lighting and adaptive Xenons
    By ukgroucho in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-09-2013, 05:35 PM
  5. Can adaptive xenons be retrofitted?
    By Genn in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-08-2009, 11:29 AM
