Thread: A3 drivers door lock and windows and lock switch not working
  1. A3 drivers door lock and windows and lock switch not working
    Jun 2020
    Swansea uk
    Hi All
    please bear with me as this is the first forum I have been on, I have a 2010 A3 2.0tdi 3 door, the drivers door won’t lock or unlock on the key fob, The other doors lock and unlock on the key fob. the locking switch on the inside of drivers door doesn’t work or light up, the electric window on the passenger side won’t work from the drivers side but does from the passenger side.
    I peeled back the rubber boot between the A pillar and the door and found two wires broke so I soldered them back together ok. I have checked the wiring from inside the footwell and through the plugs and all the way to the plug on the module connected to the window motor which all check out ok, I have checked continuity from all the plugs in the door to where they go and all check out ok. I changed The door module for a used one on the window motor and tried a new door lock mechanism too.
    I’m lost on what else it could be, can anyone help out and have any suggestions on what I can try next..
    thanks
  2. Re: A3 drivers door lock and windows and lock switch not working
    108 Post(s)
    1816 Post(s)
    The soldering won’t last long. You need to know what the central convenience system is seeing as being faulty, in some cases if you repair a fault and don’t delete the fault code, the system will still act as if the fault is still there.
  3. Re: A3 drivers door lock and windows and lock switch not working
    Near Blackpool
    48 Post(s)
    I’ve replaced the door loom on my A3 as had the snapped wires. As Crasher says the repairs will just fail again as the wiring is brittle. You’ll probably find that there are more breaks that you can’t see until you take the boot completely off.
  4. Re: A3 drivers door lock and windows and lock switch not working
    Jun 2020
    Swansea uk
    Thanks Crasher. I’ll try that on my mates scanner on Monday. I’ll let you know if it’s worked
  5. Re: A3 drivers door lock and windows and lock switch not working
    Jun 2020
    Swansea uk
    Thanks Jonathanfenton. All the wires seem ok and I have continuity through all the wires now. I’ll get the faults deleted and go from there.
  6. Re: A3 drivers door lock and windows and lock switch not working
    Sep 2012
    Oxford, UK
    I have the same problem on my sisters car, was the wiring the issue?
    I noticed when opening and closing the door the light for the window lock button intermittently lights up, so might be some wiring issue somewhere.
  1. Please Help LED light on A4 B8 door lock switch not working
    By Feemy82 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-02-2019, 02:47 PM
  2. drivers side door actuator lock not working 3B6 AWX.
    By Eugheugh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-05-2017, 04:08 PM
  3. Replies: 0
    Last Post: 02-02-2015, 11:16 AM
  4. Replies: 3
    Last Post: 23-03-2013, 10:15 PM
  5. Please Help Electric Windows Lock switch
    By k3caz in forum Bora - 1998 - 2005
    Last Post: 10-07-2008, 12:00 PM
