Thread: Intermittent low fuel pressure (P0087 - to low)
  1. Intermittent low fuel pressure (P0087 - to low)
    Apr 2018
    N.Ireland
    9 Post(s)
    Hi Folk,
    So had this low fuel pressure problem when i first purchased the car (a 2008 2.7tdi, auto). I fixed this by changing the fuel filter roughly 4 months ago. So now i have this code P0087 too low, the car is not hard to start or low on power and no other noticeable signs other than specifically, once i slow down from high acceleration i get the glow plug light and limp mode, engine off and on then we are all good again. If i drive the car easy i have absolutely no problems and great mpg.
    After a google search i am going to check the pressure regulator for aluminium swarf and work back to the fuel tank
    Any additional advice on this would be lovely.
  2. Re: Intermittent low fuel pressure (P0087 - to low)
    Apr 2018
    N.Ireland
    9 Post(s)
    I temporarily fixed this with a fuel filter change and a fuel regulator change, it was excellent for 6 months but now it has returned with different symptoms, same code. It happens when i try to accelerate from cruising. I'm wondering is this to do with the cold weather and the location of the fuel filter on these A4's?
    5211 - Fuel Rail/System Pressure
    P0087 00 [101] - Too Low
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 206158 km
    Date: 2021.01.07
    Time: 13:50:19
    MK7 Golf Estate '14 GT TDI CR150 DSG. Engine Mods: Stage 1, Rear Intake Trim
  3. Re: Intermittent low fuel pressure (P0087 - to low)
    Apr 2018
    N.Ireland
    9 Post(s)
    Today after no driving from my last post the car is back to its normal self only difference is we are +9 degrees C from it had faults. I may be ignorant to something but i'm putting this issue down to a very cold start (relatively) and the redex i had put into the tank which possible had clogged the filter in low temps.
  4. Re: Intermittent low fuel pressure (P0087 - to low)
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Have you checked the in-tank fuel pump is pumping reliably. ( assuming this car has one )
  5. Re: Intermittent low fuel pressure (P0087 - to low)
    Apr 2018
    N.Ireland
    9 Post(s)
    Hi Philip, I have not checked this, is it a VCDS check? looking online you can buy this item for the 2.7 B8 so i'm guessing it exists in my car.
  6. Re: Intermittent low fuel pressure (P0087 - to low)
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Pretty sure it doesn't show in VCDS.
    You could try un-plugging it & checking.
    But of course that doesn't prove it's pumping properly.
    Best of luck Jim.
  1. Occasional power loss and fuel pressure fault code p0087
    By Keith-i in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-10-2018, 09:11 AM
  2. Please Help Low Oil Pressure warning - Intermittent
    By tmoram86 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-12-2017, 11:53 PM
  3. Limp mode, low fuel pressure, air in fuel lines
    By Mowbz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-03-2017, 06:24 PM
  4. A6 3.0tdi quattro Oil Pressure Switch Intermittent fault
    By viperjng in forum 3.0TDi - Engine
    Last Post: 01-06-2016, 03:47 AM
  5. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
