Thread: Speed limitation
  1. Talking Speed limitation
    Jun 2020
    Aarhus Denmark
    Hello
    Can anyone help me change max speed settings ? I have tried with VCDS 20.4. When i enter new speed it is accepted. After exit it returns to the old limitation
    Jesper
    Polo 1.6 TDI 2010
  2. Re: Speed limitation
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Do you mean the actual limit on allowed speed of the car which you can't exceed (like 200km/h), or the "ping and warning message" at a speed you choose but can ignore (like 110km/h)?
  3. Re: Speed limitation
    Jun 2020
    Aarhus Denmark
    Hello.
    My car has a max of 190 Km/h. I would like to change that to 200 Km/h
    Jesper
  4. Re: Speed limitation
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Fit tyres with 5% larger diameter / circumference ?
    You have to be careful with that value, depending on the ECU. From Ross-Tech: VAG-COM: TDI VAG-COM Info (Adaptation, Channel 18):
    "It can only be adjusted downward, and it's one-way! You cannot increase the value, and if you decrease it, you're stuck with it. ... If you do mess with it and your car ends up with a lower top speed than it had before, don't call us, don't e-mail us, and don't complain that we didn't warn you!"
  5. Re: Speed limitation
    Jun 2020
    Aarhus Denmark
    Hello.
    Thanks for the warning. I have just talked with my chip-tuner. He says: No problem, but on your own risk. The risk is blowing the motor. If he can, there is a safe way.
    Jesper
  6. Re: Speed limitation
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Yes, I'd expect chip tuning to do it quite easily - its a different kind of change.
  1. Replies: 3
    Last Post: 26-04-2020, 03:12 PM
  2. Replies: 17
    Last Post: 24-03-2015, 06:08 PM
  3. Reset Trip Computer results in speed warning at low speed after start up ?
    By davemeysner in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-06-2013, 06:18 PM
  4. Replies: 19
    Last Post: 02-12-2012, 09:47 PM
  5. Torque "restriction"/"limitation", flat spots & DMFs.
    By M3 Compact in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-05-2012, 10:35 PM
