Thread: Golf Plus 2007
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
  1. Re: Golf Plus 2007
    #21
    Mar 2005
    Sorry. There are indeed 30 fuse positions. My heads gone now. Lol
  2. Re: Golf Plus 2007
    #22
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Quote Originally Posted by geoffdragon View Post
    Other issue is that the current draw is fluctuating several times a second so that has me stumped.
    Sounds like a control unit not shutting down.
    Not everything goes through the fuses under the dash, but it will go through an A or B fuse. Put the meter between battery and a battery lead on 10A scale and we can quickly work out which one.
  3. Re: Golf Plus 2007
    #23
    Mar 2005
    Will give it a go tomorrow. Thanks.
  4. Re: Golf Plus 2007
    #24
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    You might want to start with SA5 (immediately left of where the cable from battery bolts on making a gap in the line of fuses), SB28 and SB30 - they look like the ones feeding the under-dash block.
  5. Re: Golf Plus 2007
    #25
    Mar 2005
    Thanks. Raining at the moment but forecast to dry up later. Will report back. 👍
  6. Re: Golf Plus 2007
    #26
    Mar 2005
    Stopped raining so here goes.
    Meter from B- to earth lead fluctuating reading.
    Removed SB28 and SB30 - no difference.
    Disconnected SA5 and set the alarm off. Time to rethink.
    Relocked the car and put second meter across SA fuses before disconnecting.
    Only draw on SA5 (100A fuse) 24-47ma.
    Rechecked draw on B- and thats 27- 97ma.
    Discovered the max/min button on the meter. lol
    Where to go from there ?
  7. Re: Golf Plus 2007
    #27
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    So it sounds like there is another 0-50mA taking another fuse B path? I'd put the meter in place of each fuse in turn. Prob try SB8 first - radio and prone to being a drain point.
    When you say "earth lead" to you mean a braided strap you've clipped to, or the -ve cable which you've disconnected from battery?
  8. Re: Golf Plus 2007
    #28
    Mar 2005
    Yes the disconnected -ive cable to the body.
    I thought all the B fuses would have been protected by the A's but I'll give it a go.
    Cheers.
  9. Re: Golf Plus 2007
    #29
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    No, the big 80A+ A fuses are outside the box because of their physical size, connection, etc. There are supplies to various engine parts, relays, etc that go just via a smaller / blade 5A-40A B fuse.
  10. Re: Golf Plus 2007
    #30
    Mar 2005
    OK, in between showers, pulled and checked all "B" fuses.
    Number B8 less than 1ma, One or two showing around 1 ma.
    Had to make up a probe using crock clips and paper clips to get into a few.
    Nothing large showing ??????????
  1. 2007 Golf TDI Cutting out
    By BurrenD in forum Golf MK5 - 2004 - 2009
    Last Post: 22-12-2017, 01:22 AM
  2. 2007 Golf 1.9 TDI DMF
    By bp2411 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-02-2017, 04:27 PM
  3. Buying a 2007 GOLF GT TSI 1.7 170 BHP
    By byrnedave in forum New Member Introductions
    Last Post: 04-12-2011, 11:16 PM
  4. Please Help Golf plus 1.9 tdi 2007
    By boxofmatches in forum Golf MK5 - 2004 - 2009
    Last Post: 15-03-2010, 01:58 PM
