Thread: 1986 MB won't take throttle
  1. 1986 MB won't take throttle
    Jun 2020
    Stornoway
    Hello,
    I am looking for some advice, my quattro has recently developed a problem.
    It was running fine, but there was a small leak from the fuel line after the main filter, I tightened this up and fixed the leak, but now the car will not take throttle.
    It will start every time and idle nicely for a few minutes, but then will die.
    When it is idling if the accelerator is depressed the idle weakens and stalls, but if the pedal is released then the idle recovers.
    Does anybody have any similar experience or suggestions?
  2. Re: 1986 MB won't take throttle
    131 Post(s)
    1976 Post(s)
    Sounds like poor fuel delivery or pressure. Try a new filter first as I doubt you will have access to K-Jet fuel pressure testing equipment. If it has a pre filter before the pump I would get rid of it as you can no longer buy them and they are not needed.
  3. Re: 1986 MB won't take throttle
    Jun 2020
    Stornoway
    Hi Crasher,
    The filter is brand new [which is what caused the leak in the first place] but I do have a second boxed spare if you think that is the way to go.
    I have checked the pressure before the KE, this is in excess of 7 bar [limits of my guage] I do not have the facility at the moment to monitor pressure during engine operation.
  4. Re: 1986 MB won't take throttle
    131 Post(s)
    1976 Post(s)
    The fuel pressure is measured between the centre of the metering head and the Control Pressure Regulator by taking off the link pipe between these two points and fitting a pressure gauge and tap to replace it with the tap to the metering head and the gauge to the valve. With the tap closed you can see system pressure and with it open, the control pressure at that time. The system pressure should be around 4.7>5.4 Bar. The control pressure (vac hose on) warm is 3.4>3.8 Bar . I don't have an MB KE-Jet here at the moment to show you, just a K-Jet KV Coupe GT.
  1. Audi 80 1986 clutch or gearbox?
    By bm50 in forum 80 - 90
    Last Post: 28-05-2010, 08:34 AM
  2. Question 1986 Coupe Paint Code
    By smiter in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 18-04-2010, 12:43 PM
  3. Please Help mk2 gti 1986/7 headlight switch
    By Silvershoe2206 in forum New Member Introductions
    Last Post: 25-03-2009, 04:58 PM
  4. My 1986 MK 2 Jetta.
    By klunky in forum Jetta MK2 - 1984 - 1992
    Last Post: 20-05-2008, 08:54 PM
  5. 1986 coupe gt
    By dazza1 in forum Archive posts
    Last Post: 18-10-2007, 12:05 PM
