Thread: T5 AXE 7H Caravelle advice required
Results 11 to 20 of 26
  1. Re: T5 AXE 7H Caravelle advice required
    #11
    67 Post(s)
    1219 Post(s)
    The radiator fan controller (revised part number 7H0 919 506 D) is in the engine bay on the left side member
    A petition has been started to allow the use of synthetic fuels when they become available, this may allow the continued sale of ICE vehicles post 2030 and the use of classic vehicles well into the future… Their use may even be able to rival electric vehicles given the chance. Please sign this petition IF you feel the infernal combustion engine has a future if sustainable fuels are made available
    https://petition.parliament.uk/petitions/588774
  2. Re: T5 AXE 7H Caravelle advice required
    #12
    Apr 2018
    Swindon
    thanks is it accesiblt from the top or from underneath?
    I will post photos when I find as there is nothing online at all!!!
  3. Re: T5 AXE 7H Caravelle advice required
    #13
    67 Post(s)
    1219 Post(s)
    I have one in at the moment but it is in the body shop being resprayed so I can't investigate. I don't ever recall having trouble with one.
  4. Re: T5 AXE 7H Caravelle advice required
    #14
    Apr 2018
    Swindon
    its only accesible from underneath - but its dead easy to get toDSCF0003.jpgDSCF0006.jpgDSCF0007.jpgDSCF0008.jpg
  5. Re: T5 AXE 7H Caravelle advice required
    #15
    Apr 2018
    Swindon
    Nightmare continues
    New Style Module fitted - still getting
    3 Faults Found:
    16502 - Engine Coolant Temp. Sensor (G62)
    P0118 - 000 - Signal too High - Intermittent
    Freeze Frame:
    RPM: 273 /min
    Torque: 300.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 10.26 V
    Bin. Bits: 00000100
    Temperature: -6.3°C
    Temperature: 18.9°C
    18080 - Coolant Fan Control 1
    P1672 - 000 - Open or Short to Ground - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 242.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.39 V
    Bin. Bits: 00000000
    Temperature: 19.8°C
    Duty Cycle: 9.6 %
    18308 - Coolant Fan Control 2
    P1900 - 000 - Open or Short to Ground - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 242.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.39 V
    Bin. Bits: 00000000
    Temperature: 19.8°C
    Duty Cycle: 0.0 %
    Readiness: 0 0 X X X
    So I have ordered a new temp Sender to try next - another £50
    I have also checked the earths from the module wires
    What else could cause both fans to report ground/open Circuit?
  6. Re: T5 AXE 7H Caravelle advice required
    #16
    Apr 2018
    Swindon
    The 3 Engine Faults were all on the sender - fans still NOT spinning -- new scan below - any sugestions:
    Saturday,07,August,2021,12:01:02:53651
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.1.0.0
    Data version: 20170106 DS267.0
    Ross-Tech: Home
    VIN: WV2ZZZ7HZ4H039051 License Plate: T5 AFTER NEW TEMP SENDER
    Mileage: 176380km-109597mi Repair Order:
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
    57 6E 76 77 78 7D
    VIN: WV2ZZZ7HZ4H039051 Mileage: 176380km-109597miles
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 070 906 016 A HW: 028 101 073 3
    Component: R5 2,5L EDC 0000SG 5282
    Revision: 12345678 Serial number: VWZ7Z0C8174341
    Coding: 0001072
    Shop #: WSC 02756 785 00200
    VCID: 0E13C81D1A86F6314D-515E
    No fault code found.
    Address 03: ABS Brakes Labels: 7H0-907-37x-ESP-F.lbl
    Part No: 7H0 907 379 F
    Component: ESP FRONT MK25 0104
    Coding: 0006187
    VCID: 387F4EC54882188137-5124
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 7H0 820 045 G
    Component: CLIMA/AC 0101
    Shop #: WSC 00000 000 00000
    VCID: 29599B818328B109B8-5124
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    014 - Defective
    Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
    Part No: 7H0 937 049 K
    Component: BORDNETZ SGVER 1.0 1901
    Coding: 0000101
    VCID: 3A7B54CD768E0A91C1-5124
    4 Faults Found:
    01598 - Drive Battery Voltage
    002 - Lower Limit Exceeded
    00538 - Reference Voltage
    014 - Defective
    01117 - Generator Terminal DF Load Signal
    008 - Implausible Signal
    00966 - Fuse for Blinkers (S151)
    014 - Defective - Intermittent
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 F
    Component: 13 AIRBAG VW61 0R0S 0003
    Coding: 12595
    Shop #: WSC 02756
    VCID: 275D9DB9C53C8779AE-5124
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
    Part No: 7H5 920 960 K
    Component: KOMBI+WEGFAHRSP VDO V01
    Coding: 07412
    Shop #: WSC 00000
    VCID: 39794BC123880189C8-5140
    WV2ZZZ7HZ4H039051 VWZ7Z0C8174341
    Address 18: Aux. Heat Labels: 7H0-819-008.lbl
    Part No: 7H0 815 071 C
    Component: Standheizung 0206
    VCID: 285F9E8598228801A7-5140
    3 Faults Found:
    00667 - Ambient Temperature Signal
    01126 - Engine Speed Signal
    00664 - Fuel gauge
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 02756
    VCID: 70EFB6E5307280C13F-5140
    Address 45: Inter. Monitor Labels: 7Hx-951-171.lbl
    Part No: 7H5 951 171 A
    Component: Innenraumueberw. 2409
    Coding: 0000012
    VCID: 2D516F91B7C0AD2954-519A
    1 Fault Found:
    01838 - Transceiver Module 2 for Interior Monitoring (G305)
    Address 46: Central Conv. Labels: 7H0-959-433.lbl
    Part No: 7H0 959 433
    Component: Komfortgerát 0003
    Coding: 00078
    Shop #: WSC 00419
    VCID: 70EFB6E5307280C13F-4B00
    Subsystem 1 - Part No: 7H2959802A
    Component: Tõrsteuer.FS KLO 0001
    Subsystem 2 - Part No: 7H2959801A
    Component: Tõrsteuer.BF KLO 0001
    2 Faults Found:
    01134 - Alarm Horn (H12)
    49-10 - No Communications - Intermittent
    00912 - Window Regulator Switch; Front Left (E40)
    27-10 - Implausible Signal - Intermittent
    End-------------------------(Elapsed Time: 06:14)--------------------------
  7. Re: T5 AXE 7H Caravelle advice required
    #17
    Apr 2018
    Swindon
    fitted new heater control panel today and its cleared the add 08 and 18 Faults
    But g62 is back
    and new fault on 19 Can gateway climatronic?
    Coding: 0001072
    VCID: 0E13C81D1A86F6314D-5140
    2 Faults Found:
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Bin. Bits: 00000000
    Temperature: 43.2°C
    Temperature: 37.8°C
    18043 - Powertrain Data Bus
    P1635 - 000 - Missing Message from A/C Controller - Intermittent
    Freeze Frame:
    RPM: 777 /min
    Torque: 50.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 00000000
    Bin. Bits: 11100000
    (no units): 16.0
    Coding: 0006187
    VCID: 387F4EC54882188137-5140
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Part No: 7H0 820 045 AL
    Component: CLIMA/AC 0303
    VCID: 6FEDB5997D4C9F3926-5124
    Coding: 0000101
    5 Faults Found:
    014 - Defective
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    Coding: 12595
    Shop #: WSC 02756
    1 Fault Found:
    Coding: 07412
    Shop #: WSC 00000
    VCID: 39794BC123880189C8-5124
    VCID: 285F9E8598228801A7-5124
    Coding: 00006
    Shop #: WSC 02756
    VCID: 70EFB6E5307280C13F-5124
    1 Fault Found:
    01320 - Control Module for Climatronic (J255)
    Coding: 0000012
    1 Fault Found:
    Coding: 00078
    Shop #: WSC 00419
    2 Faults Found:
    End-------------------------(Elapsed Time: 06:18)--------------------------
  8. Re: T5 AXE 7H Caravelle advice required
    #18
    67 Post(s)
    1219 Post(s)
    Did you fit a brand new panel and sis you fit a new CAN BUS.
  9. Re: T5 AXE 7H Caravelle advice required
    #19
    Apr 2018
    Swindon
    yes it was a new one built in April this year but the vent controller is slightly different (it doesnt filly rotate like my old one
    the Can bus is near £600 and the dealer said that it would have to be coded?
  10. Re: T5 AXE 7H Caravelle advice required
    #20
    67 Post(s)
    1219 Post(s)
    Could you PM me the vans VIN and post the part number of the controller.
  1. Advice Required
    By vlb in forum Chat - Anything with wheels
    Last Post: 28-09-2017, 05:17 PM
  2. Advice required please
    By dadandlad in forum VCDS - General Questions
    Last Post: 29-03-2013, 01:58 PM
  3. Tyre advice for Caravelle T4
    By gervulstrammer in forum Touran - Sharan - Caravelle
    Last Post: 24-09-2009, 11:54 AM
  4. Important 1995 caravelle 2.4 diesel help required
    By GavinGD in forum The Classic VW's
    Last Post: 11-09-2009, 09:00 AM
  5. Advice required on the S5
    By AndyD1811 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 07-10-2008, 08:24 PM
