Thread: T5 AXE 7H Caravelle advice required
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. Re: T5 AXE 7H Caravelle advice required
    #21
    Apr 2018
    Swindon
    Thanks will do
    the heater controller is rubbish though - even though its from a main dealer at £173.09, the vent control dial only moves through 270 degrees and my old one would go 360 in any direction, also the signs are back to front i.e. when selecting windscreen it blows on feet, and vice versa. I pulled the dial off but it can't be flipped! I have taken it back in to show them and they are @rasing a technical ticket on it . the part guy told me that mine had been superseded 5 or 6 times. VW | New and Used Cars at Fish Bros | Swindon, Wiltshire - Fish Bros Car Dealers Swindon
    My original was 7HO 820 045 G 9B9
    the naff new one is 7HO 820 045 AL 9B9
    VIN WV2ZZZ7HZ4H039051
    As for the part number on my Can thing - I haven't found it yet
  2. Re: T5 AXE 7H Caravelle advice required
    #22
    Apr 2018
    Swindon
    So the AL has gone back for a Refund and I now ordered a NOS AB!
  3. Re: T5 AXE 7H Caravelle advice required
    #23
    Apr 2018
    Swindon
    The AB arrived today and what VW told me was a load of BS
    So I have gone from a 2003 G to 2005 AB
    new scan below - Cleaner than a Trainee Nun......
    But I am still not getting cold air
    screen shots from the Measuring blocks below also
    Code:
    Monday,16,August,2021,16:38:48:53651
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.1.0.0
    Data version: 20170106 DS267.0
    Ross-Tech: Home
    VIN: WV2ZZZ7HZ4H039051   License Plate: AFTER AB CONTROL DIALS
    Mileage: 176420km-109622mi   Repair Order:
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV2ZZZ7HZ4H039051   Mileage: 176420km-109622miles
    Address 01: Engine        Labels: Redir Fail!
       Part No SW: 070 906 016 A    HW: 028 101 073 3
       Component: R5 2,5L EDC 0000SG  5282
       Revision: 12345678    Serial number: VWZ7Z0C8174341
       Coding: 0001072
       Shop #: WSC 02756 785 00200
       VCID: 0E13C81D1A86F6314D-515E
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP-F.lbl
       Part No: 7H0 907 379 F
       Component: ESP FRONT MK25      0104
       Coding: 0006187
       VCID: 387F4EC54882188137-5140
    Address 08: Auto HVAC        Labels: Redir Fail!
       Part No: 7H0 820 045 AB
       Component: CLIMA/AC            0303
       Shop #: WSC 00000 000 00000
       VCID: 65C1D7B1AFB055695C-5124
    Address 09: Cent. Elect.        Labels: 7H0-937-049.lbl
       Part No: 7H0 937 049 K
       Component: BORDNETZ SGVER 1.0  1901
       Coding: 0000101
       VCID: 3A7B54CD768E0A91C1-5124
    Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
       Part No: 1C0 909 605 F
       Component: 13 AIRBAG VW61 0R0S 0003
       Coding: 12595
       Shop #: WSC 02756
       VCID: 275D9DB9C53C8779AE-5140
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H5 920 960 K
       Component: KOMBI+WEGFAHRSP VDO V01
       Coding: 07412
       Shop #: WSC 00000
       VCID: 39794BC123880189C8-5124
       WV2ZZZ7HZ4H039051     VWZ7Z0C8174341
    Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
       Part No: 7H0 815 071 C
       Component: Standheizung        0206
       VCID: 285F9E8598228801A7-5124
    Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    0001
       Coding: 00006
       Shop #: WSC 02756
       VCID: 70EFB6E5307280C13F-5124
    Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
       Part No: 7H5 951 171 A
       Component: Innenraumueberw.    2409
       Coding: 0000012
       VCID: 2D516F91B7C0AD2954-517C
    1 Fault Found:
    01838 - Transceiver Module 2 for Interior Monitoring (G305)
                004 - No Signal/Communication
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433
       Component:    Komfortgerát     0003
       Coding: 00078
       Shop #: WSC 00419
       VCID: 70EFB6E5307280C13F-4B00
       Subsystem 1 - Part No: 7H2959802A
       Component: Tõrsteuer.FS KLO 0001
       Subsystem 2 - Part No: 7H2959801A
       Component: Tõrsteuer.BF KLO 0001
    End-------------------------(Elapsed Time: 06:28)--------------------------hvac.jpghvac 2.jpg
  4. Re: T5 AXE 7H Caravelle advice required
    #24
    134 Post(s)
    2005 Post(s)
    Modulated displacement compressor, no codes, good gas, new compressor… simples.
  5. Re: T5 AXE 7H Caravelle advice required
    #25
    Apr 2018
    Swindon
    Cheers any recommendations on a compressor brand/model?
    Also what about my the Clutch - mine runs on Elastic Gates couplers (which are new)
  6. Re: T5 AXE 7H Caravelle advice required
    #26
    134 Post(s)
    2005 Post(s)
    I would fit a Denso new outright compressor, if the freewheel and coupling are new, reuse them.
  1. Advice Required
    By vlb in forum Chat - Anything with wheels
    Last Post: 28-09-2017, 05:17 PM
  2. Advice required please
    By dadandlad in forum VCDS - General Questions
    Last Post: 29-03-2013, 01:58 PM
  3. Tyre advice for Caravelle T4
    By gervulstrammer in forum Touran - Sharan - Caravelle
    Last Post: 24-09-2009, 11:54 AM
  4. Important 1995 caravelle 2.4 diesel help required
    By GavinGD in forum The Classic VW's
    Last Post: 11-09-2009, 09:00 AM
  5. Advice required on the S5
    By AndyD1811 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 07-10-2008, 08:24 PM
