Thread: i need new coil springs
Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
  1. Re: i need new coil springs
    #41
    1840 Post(s)
    Private message me your VIN but I may find it awkward to do from home and have to do it at work on Monday.
  2. Re: i need new coil springs
    #42
    Apr 2016
    London/UK
    23 Post(s)
    my plan is to change my rear suspension only from 1BE to 1BA. got my shocks (Meyle 1267250036) and i was going to get a pair of Bilstein 36-234974 springs.
    got told by bilstein that this is a made-to-order item and it'll take 4 weeks. what a joke
    looking to get a pair of new smtg's (any good brand) or used oem's just to see if it'll comfort the ride.
  3. Re: i need new coil springs
    #43
    1840 Post(s)
    Prod me tomorrow as it need to do this at work and not under the influence of vodka.
  4. Re: i need new coil springs
    #44
    Apr 2016
    London/UK
    23 Post(s)
    Hi. Could you pls look into it today?
  5. Re: i need new coil springs
    #45
    1840 Post(s)
    The spec of your rear springs is 1BE+0YJ and part number 8K0 511 115 HA (1 x grey, 1 x grey, 3 x white) so you need a 1BA+0YJ and funnily enough that is the previous one in the list on ETKA, 8K0 511 115 DG (1 x grey, 2 x pink) at £137.86 but personally I would use a Suplex 03265. The damper needs to be a K8B+1BA, as your OE dampers were a Monroe 4G5 513 035 C that would make the one you need 4G5 513 035 but you could also use 4G5 513 035 F which is a Monroe 376025SP. The new UK importer of Suplex is also a Monroe agent. In your case the Meyle 126 725 0036 is perfect.
  6. Re: i need new coil springs
    #46
    Apr 2016
    London/UK
    23 Post(s)
    thanks a lot. that confirms my research .
    i'll go ahead and pair up :
    monroe SP3925
    Meyle 126 725 0036
    just hope i'll have some dampening and not a lot of rebound
    i'll research to find what i need for the front too (1BA). thanks again
  7. Re: i need new coil springs
    #47
    1840 Post(s)
    The springs are 1BE+0JG so 1BA+0JG would be 8K0 411 105 DG 1 x orange 1 x violet (Suplex 03250) . The 1BE+0K0 front dampers are 4G0 413 031 C (again Monroe OE) and so 1BA+0K0 in Monroe are 4G0 413 031 AD (Monroe 376243SP).
  1. Question Coil springs
    By maccaone in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 28-07-2015, 03:29 PM
  2. Question 1.9 tdi coil springs
    By switchblade in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2011, 06:30 PM
  3. coil springs
    By shaunebabe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-11-2008, 08:13 PM
  4. Question front coil springs
    By robertb5714 in forum New Member Introductions
    Last Post: 05-09-2008, 09:31 AM
  5. coil springs
    By panther in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-05-2007, 06:10 PM
