Thread: Sticky clutch pedal a3 2011
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. Re: Sticky clutch pedal a3 2011
    #21
    Jun 2019
    Finistère, France
  2. Re: Sticky clutch pedal a3 2011
    #22
    Jun 2019
    Finistère, France
    Here are the present numbers :
    flywheel: ZSB 03L 105 266 BQ
    clutch disc: LUK hulu4 022 141 031 S
    pressure plate: 03L 141 025 T
  3. Re: Sticky clutch pedal a3 2011
    #23
    134 Post(s)
    1996 Post(s)
    A bit complex to do on my iPad, at work I would be using two PC’s to cross check all the numbers. According to Tec Doc that should be the correct LUK kit for your car. To have a mixture of Sachs and LUK from the factory is nothing unusual, som part numbers are interchangeable and others aren’t... a complex subject so go with whichever Sachs or LUK kit your suppler says as it is their job to get it right although against REG number or even VIN look up, none genuine parts suppliers do make a LOT of time costly mistakes (Using so called K type numbers) so when I order something I decide what comes in as I make less mistakes than they do by putting the applications through ETKA FI Suggestion and then finding the aftermarket manufacturers cross reference number using Tec Doc, this way I keep **** up’s to a minimum.
  4. Re: Sticky clutch pedal a3 2011
    #24
    Jun 2019
    Finistère, France
    Hi there, I think I will go with the one you sent and cross fingers, when I put the numbers from the parts that came off, No parts come up with those numbers. So fingers crossed, and would you mind confirming that (G 052 171) is the gearbox oil spec I need please?
    EDIT : I can find a kit with the same Flywheel number, but none of the other part numbers match up with the other parts I have, or other kits, driving me nuts. I don't know how you do it mate and at the same time be patient and take the time to explain to people like me
    . Worst case sénario it will get sent back.
  5. Re: Sticky clutch pedal a3 2011
    #25
    134 Post(s)
    1996 Post(s)
    In my life of being an independent VAG specialist garage, parts supply is THE most irritating, stressful and frustrating part of my job. I have ALL the tools (official and not so) to find out what how and where so I can give a supplier their own part number and still they **** it up a good 20% of the time. I must say that Euro Car Parts seem to have improved markedly in the last few months... possibly being less busy has allowed them more time to take care. One point that can shock you is how slow parts supply inside the UK can be. A number of times I have ordered odd ball things from the USA at the same time as a normal part from the UK, both for the same car, and the part from the USA arrives first.
  6. Re: Sticky clutch pedal a3 2011
    #26
    Jun 2019
    Finistère, France
    In France the shipping takes a while too, most of the time 1 - 2 weeks. From all the car parts I have ordered (touch wood) I have only received 1 wrong part. Hopefully it will stay that way. The clutch kit and oil is on its way. I will keep this post updated when all back together and hopefully driving.
    Thank you again for all the time you have spent helping me out. I really appreciate it.
  7. Re: Sticky clutch pedal a3 2011
    #27
    Jun 2019
    Finistère, France
    And Im back ! Shipping took a while, had to run around a bit but finally got the parts last night, fitted everthing this afternoon. Only hiccup was the gear selection was funky, so had to put the lever in home position etc. Once again Crasher you were spot on on the parts, I can't thank you enough for all your help. Car drives like a dream, clutch and gears are better than before !
    Thank you again, and have a good weekend all. Jo
  8. Re: Sticky clutch pedal a3 2011
    #28
    Oct 2020
    Sweden
    So, it appears that I have pretty much the exact same symptoms as thread starter, with what I believe is the same vehicle.
    Clutch has in general been very soft. Problems started with clutch dropping lower to the point where it even got stuck at the floor. Problem is especially bad once the car has warmed up.
    Have tried bleeding, both by pushing oil through slave cylinder and by applying 2 bars of pressure at reservoir (bleeding at slave valve).
    Have tried "bleeding" clutch release bearing/slave cylinder by inserting small tube VWVortex.com - How to bleed your 02M clutch slave cylinder, the effective way.
    Nothing seems to have improved the situation. Upon checking with workshop, I was told it was likely the master cylinder and that it's a known point of failure on these vehicles (had recently fixed another one with similar problem). My master cylinder appears to be somewhat dry on the outside upon inspection (without complete disassembly).
    Could it still be the master cylinder, or is it almost 100 % certain it's the slave cylinder / clutch release bearing?
    Appreciate any input.
  9. Re: Sticky clutch pedal a3 2011
    #29
    134 Post(s)
    1996 Post(s)
    What is your car?
  10. Re: Sticky clutch pedal a3 2011
    #30
    Oct 2020
    Sweden
    What is your car?
    Audi A3 2012, CFFB engine 140 hp 2.0 TDI, 6-speed transmission so it has the clutch release bearing inside gear box.
  1. Sticky brake pedal help what could it be ?
    By malibu2007 in forum Chat - Anything with wheels
    Last Post: 13-06-2017, 07:52 PM
  2. Replies: 0
    Last Post: 03-02-2017, 04:10 PM
  3. Please Help Sticky Clutch Pedal - Sharan 1.9 TDi '05
    By HorseOffaGypsy in forum Touran - Sharan - Caravelle
    Last Post: 05-01-2016, 02:17 PM
  4. 'Sticky' throttle pedal
    By Richie Blackmor in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-03-2014, 01:46 PM
  5. Question Mk5 Clucth Pedal sticky!!!
    By onzarob in forum Golf MK5 - 2004 - 2009
    Last Post: 02-09-2011, 10:55 PM
