Thread: Mk 6 Intermittent Wiper Relay - location
  1. Mk 6 Intermittent Wiper Relay - location
    May 2020
    West Sussex
    My wipers work in all modes/speeds, however the intermittent wipe is NOT intermittent anymore i.e. it simply goes at the slower of the two speeds rather than an intermittent wipe.
    I assume this is related to a relay fault. So I have located the relays behind the small cubby under the light switch but cannot find a diagram or details of which relay it is anywhere.
    Anyone point me in the right direction ?
    Thanks in advance - Pete 2011 1.6 tdi
  2. Re: Mk 6 Intermittent Wiper Relay - location
    2009 Post(s)
    Good luck looking for a wiper relay, there isn’t one... The motor is controlled by a digital LIN BUS command from the Central Electrics, AKA body control module. The common fault is the column switch and a fault code scan of the steering column controller (yes another separate ECU) usually shows the switch is faulty.
  3. Re: Mk 6 Intermittent Wiper Relay - location
    May 2020
    West Sussex
    Thanks Crasher - saved me a lot of wasted time.
    Pete
  1. Question Location of connector for wiper intermittent function signals
    By JohnPierpoint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-01-2019, 03:16 PM
  2. wiper relay location
    By mk4bennyboy in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-11-2014, 11:06 PM
  3. A4 Avant Wiper Relay Location
    By ian1234 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-03-2009, 10:44 PM
  4. Audi A4 Rear Wiper Relay Location
    By jethroedavies in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-02-2009, 12:22 PM
  5. Intermittent Wiper Relay - HELP!
    By Steve P in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-06-2007, 01:00 PM
