Thread: 2013 A6 - vibrations under braking but not warped rotors
  1. 2013 A6 - vibrations under braking but not warped rotors
    May 2020
    Galway, Ireland
    hi there, I have a 2013 A6 with a vibration issue in the front end. The car vibrates violently under braking especially when lightly applying the brakes. i did the most obvious thing which was to change the rotors and pads. However, that did not fix the problem. I've also changed the wheel bearings but still no use. I have cleaned both pads and rotors to remove any deposits and also checked the rotors to be certain that they are true - all ok. The problem persists. I also think I can feel some vibration when accelerating and at higher speed but cannot be certain. Anyone with any ideas of what this problem might be?
  2. Re: 2013 A6 - vibrations under braking but not warped rotors
    Aug 2013
    Dalry - Ayrshire-Scotland
    30 Post(s)
    Discs definitely fitted correctly.. seated aligned correctly on hubs etc.. ?... thinking that the hubs need to be totally clean to align the new discs. Is there no change to the vibration... given the work you have all ready done..
    A6 Black Edition - 2014 - 2.0 TDI Manual
    Daytona Grey Pearl, Full LED Headlights, Technology Pack, Advanced Key
    4 Zone Climate Control & Heated Seats, Colour DIS, Lighting Pack - LED Ambient Lighting.
  3. Re: 2013 A6 - vibrations under braking but not warped rotors
    Jan 2016
    Merthyr Tydfil
    25 Post(s)
    Wheels balanced properly?? Might be buckled?
  4. Re: 2013 A6 - vibrations under braking but not warped rotors
    Apr 2009
    Surrey
    182 Post(s)
    Have the whels recently been refurbished? I have read elsewhere that if the the contact point between wheel and hub is painted then it can cause problems with vibration as the wheel is not tight and flat against the hub
  5. Re: 2013 A6 - vibrations under braking but not warped rotors
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    Another thing to check is that the hub flanges are straight.
    I had this on my C5 A6, after years of new tyres, swapping wheels round changing discs and pads etc and still had braking vibration.
    I discovered it by running the car jacked up with the wheel off, and noticed the disc was wobbling very slightly. Replaced the hub, and no more vibration.
  1. Warped discs
    By A6S in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 24-09-2017, 01:47 AM
  2. warped discs?
    By gdallas in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-10-2015, 11:12 AM
  3. Warped brake disks - second set
    By johnmccracken in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-04-2010, 09:05 PM
  4. Warped rotors
    By gruffly in forum Vento - 1994 - 1998
    Last Post: 19-08-2009, 07:19 PM
  5. Warped Discs?
    By cam7777 in forum Fabia
    Last Post: 10-05-2008, 10:08 PM
