Thread: A6 C6 Allroad - air suspension noises
  1. A6 C6 Allroad - air suspension noises
    Apr 2017
    Wells, England
    I have a 2008 Allroad w/ 115k. Yesterday when I got home I locked the car and there was briefly a 'whoosh' noise from the o/s/f area. I had left it in Allroad L4, it lasted two seconds max and didn't appear to lose any air. I got back in and no warning lights appeared, it was still on L4 and I put it down to Auto L2, no problem. Locked it and once again the same noise happened. I use the various suspension settings a lot and the suspension has never failed nor dropped overnight. Is this noise anything to be concerned about?
    The previous owner told me it occasionally drops on one rear corner if left for a while but this has never happened to me. However, the battery isn't that old and always seems to be a bit weak, occasionally needing a jump start. Is it possible the rear bag is leaking and the compressor is just always keeping it up, hence the battery being weak, or am I just overthinking this and it's more likely to be a battery issue?
    Also, having just used the suspension with engine off for the first time I've discovered it's quite creaky at both ends when raising and lowering, is this normal?
    I had an Allroad previously and the air suspension was a huge headache so I'm always a bit concerned about it.
    Thanks.
    2008 A6 Allroad 2.7 TDI 120k
    2010 A6 2.0 TDI (134) 603k (!)
  2. Re: A6 C6 Allroad - air suspension noises
    131 Post(s)
    1976 Post(s)
    The creaking is normal, especially at the back with the parking brake on.
  1. Front Suspension noises.
    By quattrokid in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-11-2015, 08:06 PM
  2. A6 3.0 suspension noises
    By xf8u39 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-04-2013, 12:12 PM
  3. Noises on suspension
    By scousefly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2008, 10:50 PM
  4. Passat 1.8T suspension noises
    By The Stagg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2007, 05:49 PM
  5. A4 Suspension noises
    By scottya4 in forum Audi A4 - Archive Topics
    Last Post: 03-08-2007, 12:08 PM
