Thread: License plate lights
Results 1 to 9 of 9
  1. License plate lights
    Apr 2020
    Wirral
    Hi All
    I have a A6 Avant 2009 and have a problem with the license plate lights there’s no power coming from the comfort module in the boot I have ordered a replacement module but due to the present climate will take some time to get it my question is can I remove the module and check for anything obvious without causing any problems or does anyone have any other ideas of what I can do
    cheers
  2. Re: License plate lights
    Jul 2008
    Lisburn
    16 Post(s)
    module may not be at fault - if a bulb blows / loose connection etc the module will shut down the power - found this out the hard way myself when trying to diagnose an intermittent brake light
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: License plate lights
    Jul 2013
    76 Post(s)
    Have you checked the wiring the conduit from the roof to the tailgate as wires can snap.
    Dan
    2009/2010 2.0 TDIe SE
  4. Re: License plate lights
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Is there continuity from a thin grey+yellow wire at position 9 of a 15 pin connector on the module to the license plate lamps? If you put 12V to that wire from cigarette socket while unplugged to lamps light up (assuming they are incandescent type - not a good idea if they are LED)?
  5. Re: License plate lights
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Also, to add what VAG-Abound said, there is also a 17 pin connector in the right D-Pillar and pin 4 (grey/yellow) and another connector in rear Lid (pin 4) if you need to follow the circuit to the lamps.
    Alan.
    VW T6 150 DSG Camper £££
  6. Re: License plate lights
    Apr 2020
    Wirral
    Thanks for the replies I will have a look today and get back at some point later
    cheers
  7. Re: License plate lights
    Apr 2020
    Wirral
    Hi all
    I got totally lost looking for the fault and now have a different comfort module exactly the same number can I just change them over or will I need to get the module programmed by the dealer?
  8. Re: License plate lights
    Oct 2019
    Peterborough, England
    23 Post(s)
    What do you mean, if it is the same number then that should be good....?
  9. Re: License plate lights
    Apr 2020
    Wirral
    The code number on my existing module is the same as the module that I have bought although this from a different A6 so is it possible to do a straight exchange?
  1. Question A4 Avant License Plate Lights
    By paulyb71 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2013, 10:05 PM
  2. How to remove rear license plate lights?
    By kinlongso in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-11-2012, 06:44 PM
  3. License plate lights
    By mlgt in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-09-2012, 06:27 PM
  4. Question License Plate
    By mattgee in forum Chat - Completely Off Topic
    Last Post: 01-04-2009, 10:37 PM
  5. WTT: North American license plate tub
    By porkchop_man in forum Golf MK3 - 1993 - 1999
    Last Post: 10-02-2008, 05:09 PM
