Thread: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
  1. 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    Mar 2008
    Old Wessex
    Hi all
    Tried searching but could not really find anything...
    Anyway, I have a 2010 Passat with 170k miles on the clock. Still going strong except for one thing - at idle the revs fluctuate and the engine shakes.
    We have recently replaced all the injectors and tried another fuel pressure rail, which has not cured the problem.
    Diagnostic scan shows no fault codes, but we found out that the fuel pressure was not consistent on all cylinders.
    Any ideas?
    - VW Golf 1.9 GT TDI (130) - 2003
    - VW T5 Camper - 2.5 TDI - 2008
    - VW Passat Estate - 2.0 TDI - 2010
  2. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    1999 Post(s)
    When you fitted the new injectors, did you enter the new IMA codings in the injector tables?
  3. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    Mar 2008
    Old Wessex
    Thanks - yes the IMA codes were entered.
    We took it to a VW specialist who tried a few obvious things and made a few suggestions. None seemed to make a difference.
    Premium diesel tends to improve things slightly.
    Just wondered if there might be any other ideas that were missed.
  4. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    1999 Post(s)
    Study the high pressure pump values and other measuring block data.
  5. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    Mar 2010
    Derry ireland
    67 Post(s)
    is their any particular time this starts either cold or warm any black smoke at start up or at running temperature maybe a dribbling injector (faulty) you could check by the ohms reading at each injector 2 pins if you get a reading with a multimeter between 1 of these 2 pins and a reading at theout side body of injector then the injector insulation is faulty (injector gossed) Regards Mickeybo
  6. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    Mar 2008
    Old Wessex
    I think this was probably carried out when it went to the garage. Can this be done with an OBD reader? If so I can borrow one to use at home.
    Quote Originally Posted by mickeybo View Post
    It happens at all times, from start-up and throughout a journey of any length. It doesn't seem to be affected by engine or ambient temperature.
    As mentioned, we swapped all the injectors and this did not cure the problem.
    Other than the erratic idle, the car drives really well and mpg is consistently good.
    I think it's safe to say it is some kind of fueling problem but it doesn't seem to be the injectors.
    I am no mechanic - I am just trying to narrow down what else to get changed/checked/swapped.
    Thanks!
  7. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    1999 Post(s)
    Quote Originally Posted by the surfer View Post
    Only if it will show measuring block data.
  8. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    A reader that can display Live Data the VCDS Measuring Block equivalent when the engine is running. Usually such devices have the functionality to read live outputs, voltages, temperatures etc., etc. from the sensors / modules connected to the ECU. Readers that can identify the modules first and foremost otherwise they are not likely to work that well on VAG cars. ODB output is usually limited and a more detailed query level required.
  9. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    Dec 2016
    lincoln
    24 Post(s)
    I had the exact same problem with my 58 170PD. Turned out to be the Torsion Value was miles out after previous owner had a Timing Belt change. Took 4 different garages to actually get it right. Once it was within range car idled like a dream.
    Current Vehicles
    Passat B6 Estate 170PD (Bluefin Installed 200BHP) BMR Highline
    Aprilia RSV 1000 Factory
  10. Re: 2010 Passat 2.0 TDI - Erratic/fluctuating revs at idle
    1999 Post(s)
    Unfortunately this is a Common Rail TDI whereas yours would have been a PD TDI and they don’t respond the way a PD does to the cam timing being slightly out.
  1. BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    By gupsterg in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-05-2025, 12:28 PM
  2. Erratic Idle Revs
    By Padwick in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-12-2011, 11:52 AM
  3. Question Engine Revs Fluctuating?????
    By Fattrucker in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-01-2011, 10:21 PM
  4. Idle erratic, revs dont come down quick when come to a stop!
    By enright86 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2008, 02:39 PM
  5. Fluctuating Revs on a 52 Lupo
    By Tomangela in forum Polo - Derby - Lupo - Fox
    Last Post: 10-08-2007, 09:15 PM
