Thread: Audi TT Mk1 225bhp NON STARTER
Results 11 to 18 of 18
Threaded View
  1. Audi TT Mk1 225bhp NON STARTER
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All,
    I am haveing a starting problem with my Audi TT Mk1 225bhp APX engine code 2000year.
    Car ran spot on for the last few months, came out last weekend turns over as normal just not firing into live.
    I have lent my Vagcom out so rang the RAC they came out, bloke said there is no sound from the fuel pump, jacked the car up and when turning the engine over knocked the bottom of the fuel tank with hammer.
    He then stood up and said 'The fuel pump is not working'
    He then plugged the RAC diagnostic kit in and came back with the fault code:
    DTC 16706 Engine speed sensor input circuit no signal ('There is no engine RPM signal in Live data when turning the engine over, I would therefore say the Engine speed sensor (crankshaft sensor) is faulty.
    I have now replaced the Crankshaft sensor, turned the engine over still not starting and no sound from the fuel pump, I have now replaced the fuel pump. Still the same situation the engine does not start and no sound from the fuel pump.
    I have checked the fuel pump 20amp fuse and this is Good, I have also felt a 'Click' from the fuel pump relay (number 167)
    Any one got any ideas please, is the car fitted with a crash inertia switch that could be causing this none start??
    All ideas greatly received thanks
  1. Yr 2000 Audi TT 225BHP Starting Problem
    By roybailey in forum TT - 8N Forum - 1998 - 2006
    Last Post: 22-07-2010, 08:30 AM
  2. Audi TT 225bhp engine and gearbox
    By Raphael in forum TT - 8N Forum - 1998 - 2006
    Last Post: 11-09-2009, 03:18 PM
  3. Audi TT 225bhp - 2000 over heating
    By BeasTT in forum TT - 8N Forum - 1998 - 2006
    Last Post: 25-02-2009, 11:33 PM
  4. Audi TT 225bhp 2000MY 17978 Code
    By christianbeccy in forum TT - 8N Forum - 1998 - 2006
    Last Post: 18-04-2008, 01:00 PM
  5. Did Audi produce a 225BHP Avant?
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-12-2007, 10:57 PM
