Thread: VW golf mk5 starting problems
Results 11 to 20 of 21
  1. Re: VW golf mk5 starting problems
    Dec 2017
    Oxford
    Totally confused now! I’ve never seen a relay in this position in all the years I’ve owned this car, I don’t mean this being rude! The only 2 relays I’ve seen is position HHZG a relay with no53 & position KL75 relay with no460 on it. Car is 20l gt tdi BKD engine. What exactly do these certain relays do?
  2. Re: VW golf mk5 starting problems
    Dec 2017
    Oxford
    I see now I did a typing error on the engine code previously. Please except my apology.
  3. Re: VW golf mk5 starting problems
    1837 Post(s)
    Yes the BDK is a 2L SDI version of the BKD, to be honest pretty stupid of VAG making the code easy to mix up for a similar engine used in the same car. Private message me the cars REG so I can look at the specific wiring diagram.
  4. Re: VW golf mk5 starting problems
    1837 Post(s)
    It is a type 1K1 262 with a BKD engine, GRF gearbox and was built 21-09-04 as a 2005 model year car. I will try and look into the relay positions later.
  5. Re: VW golf mk5 starting problems
    Dec 2017
    Oxford
    Thank you Crasher!
  6. Re: VW golf mk5 starting problems
    Dec 2017
    Oxford
    Hi! Just to update & also maybe help other people with the same fault as mine being a intermittent non starter & fan running on full speed. After changing ignition switch, ignition relays, battery & spending hours on checking all wiring it finally come down to a faulty ECU which as now been replaced & reprogrammed & all starting up & working fine for now. Thanks again to Crasher for all your help & suggestions as always. ��
  7. Re: VW golf mk5 starting problems
    #17
    1837 Post(s)
    Faulty ECU's are very rare, you were unlucky.
  8. Re: VW golf mk5 starting problems
    #18
    Jul 2020
    Londonderry
    Don’t know if this correct or if I should start a knew thread but here goes.
    I’m having intermittent starting problems with an 06 golf 1.9 tdi. Been remapped recently to around 150 bhp. The engine with go through the motions as if it’s about to start then the oil pressure light comes on then after a few more seconds the engine kinda crawls into life. It’ll start 1st turn for a few days then back to the same problem again of turning over then crawling into life. Mechanic can’t find any faults on the pc. He’s replaced a non return valve re: fuel. Done a full service. Checked fuel pump under back seat, all without faults , he has it away today to change camshaft sensor hoping this with sort it out. Any advice is very welcome
    Ps: I’m not mechanically minded
    TIA
  9. Re: VW golf mk5 starting problems
    #19
    1837 Post(s)
    The oil pressure warning is nothing to worry about, you will get that under long cranking with no start. What is your chap using to read the fault codes?
  10. Re: VW golf mk5 starting problems
    #20
    Jun 2021
    Lancing
    Hi all,
    I am having this intermittent stop and start issue with my car. Sometimes it starts and goes fine for few mins and then engine cuts off and then when I wait few seconds and start again, it goes fine for long time without any issues. Happens time to time but no warning light on desk too. Help plz... Thanks
  1. golf mk3 starting problems
    By pooly in forum Golf MK3 - 1993 - 1999
    Last Post: 18-06-2009, 03:16 PM
  2. Golf MK5 starting-up problems?
    By AndyF in forum Golf MK5 - 2004 - 2009
    Last Post: 07-02-2008, 06:42 PM
  3. mk 3 golf starting problems
    By tward11 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-04-2007, 09:18 PM
  4. Problems with Starting on Golf TDI
    By SLH in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-03-2007, 08:51 AM
  5. Starting Problems with Golf
    By SLH in forum Chat - Anything with wheels
    Last Post: 30-03-2007, 04:01 PM
