Thread: 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
Results 1 to 10 of 10
  1. Exclamation 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    Apr 2020
    My Passat has been having some running issues recently. Last week the battery wouldn't hold charge and the car started to judder and lose power. So I parked it up and ordered a new battery which arrived today. Thinking this would resolve the issue I have installed the new battery only to find the car will not start, it doesn't even crank or click.
    I get plenty of warning lights on the dash and for some reason the engine fan revs up and stays on what sounds like max until I pull the key out. So VCDS out and scanned (results below) looks like I can no longer talk to the engine module. Read lots of different forums but cant find a solid answer or solution.
    Anyone seen anything like this before? Any help would be greatly appreciated.
    Code:
    Chassis Type: XX (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61
              62 65 72
    VIN: XXXXXXXXXXXXXXXXX
    01-Engine -- Status: Cannot be reached 1100
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    Address 03: ABS Brakes        Labels: 3AA-614-109.clb
       Part No SW: 3AA 614 109 M    HW: 3AA 614 109 M
       Component: J104   C2 450M V4A4 0005
       Revision: --H07---    Serial number: 00000004174448
       Coding: 0002992
       Shop #: WSC 00028 028 00001
       VCID: 377B5D8746CF56A66A7-8062
    1 Fault Found:
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 4
                        Reset counter: 164
                        Mileage: 211779 km
                        Time Indication: 0
                        Date: 2021.14.17
                        Time: 01:27:41
                 Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 11.25 V
                        Bin. Bits: 00011111
                        Count: 217
                        Hex Value: 0x0000
    Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
       Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000000003
       Shop #: WSC 00028 028 00020
       ASAM Dataset: EV_Climatronic A01010
       ROD: EV_ClimaAutoBasis_SE36.rod
       VCID: 8009765B1B81511E1BD-80D5
    1 Fault Found:
    13701376 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 211779 km
                        Date: 2021.14.17
                        Time: 01:27:39
    Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
       Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
       Component: BCM PQ47 H    413 0452
       Revision: BB413001
       Coding: 000000000000000000180080140081E443D16488406C81206480C7200041
       VCID: 38795EBB8BD159DE63D-806D
       Subsystem 1 - Part No: 3AC 955 119
       Component: Wischer 14041  26  0612
       Coding: 00B795
       Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS 050511 05  54  0403
       Coding: 0730ED
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 211779 km
                        Time Indication: 0
                        Date: 2021.14.17
                        Time: 01:27:41
                 Freeze Frame:
                            Term 15 On
                        Voltage: 11.45 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__102 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0P884M26
       Coding: 0012338
       VCID: 4C91126B2F49C57E375-8019
       Subsystem 1 - Serial number: 6332MTS605600961
       Subsystem 2 - Serial number: 6342MTS611390961
       Subsystem 3 - Serial number: 6351HTS6LTMGV9KR
       Subsystem 4 - Serial number: 6361HTS6HBR7V9KJ
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    No fault code found.
    Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
       Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
       Component: LENKS.MODUL   014 0140
       Revision: FF010040    Serial number: 20110504300958
       Coding: 018A250000
       ASAM Dataset: EV_VW360SteerWheelUDS A03004
       ROD: EV_VW360SteerWheelUDS.rod
       VCID: 72EDAC93A52DF38E9D9-8027
       Multi Function Steering Wheel Control Module:
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
       Component: E221__MFL-TK6  H06 0022
       Coding: E20000
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3AA 920 970 A    HW: 3AA 920 970 A
       Component: KOMBI         H20 0420
       Coding: 161F00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 316F639F60AB8896243-8064
    2 Faults Found:
    12648448 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 211779 km
                        Date: 2021.14.17
                        Time: 01:27:39
    12671232 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 211779 km
                        Date: 2021.14.17
                        Time: 01:27:39
    Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 G    HW: 1K0 907 951
       Component: J533  Gateway H41 1614
       Revision:   H41       Serial number: 300411F2001900
       Coding: 461007
       VCID: 34616A8B97B9BDBE4F5-8061
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 211779 km
                        Time Indication: 0
                        Date: 2021.14.17
                        Time: 01:27:40
    03075 - Parallel Parking Assistance Control Module (J791)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 211779 km
                        Time Indication: 0
                        Date: 2021.14.17
                        Time: 01:27:41
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0399
       Revision: 00043000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: F6E5108381456FAE311-80A3
       Subsystem 1 - Part No: 3C0 905 861 J
       Component:    ELV          029 0380
       3C0905861J     ELV          029 0380
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669874337
       Coding: 020000
       VCID: 28598EFB5B71C95EF3D-807D
    Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
       Part No SW: 3C0 035 279     HW: 3C0 035 279
       Component: RNS315        H05 0010
       Serial number: VWZAZ2L3337208
       Coding: 040004010400000000011000
       ASAM Dataset: EV_RNS315VWEUV1UDS A01005
       ROD: EV_RNS315VWEUV1UDS.rod
       VCID: E0C956DBFBC1F11E7BD-80B5
    Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb
       Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0534
       Revision: 12110009    Serial number: 0002767103
       Coding: 0202B7
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 3567578F94C3A4B678B-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0408
       Serial number: 00000002130452
       Coding: 000290
    Address 44: Steering Assist        Labels: None
       Part No: 1K5 909 144 H
       Component: EPS__FLS Kl+ 195  % 3201
       Revision: 00H20050
       Shop #: WSC 65564 030 00001
       VCID: 34616A8B57B9BDBE4F5-8061
    2 Faults Found:
    03803 - Steering Angle Sensor for Steering Aid
                005 - No or Incorrect Basic Setting / Adaptation - MIL ON
                 Freeze Frame:
                        Fault Status: 11100101
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 211779 km
                        Time Indication: 5
                 Freeze Frame:
                        Battery Volts: 139.0 V
                            DU
                        Temperature: 18.0°C
                        Count: 2
                        Steering Angle: 0.00°
                        Inj. Quantity: -0.00 mg/str
                            SteerAng n.Init
                        Ign. Timing: 10.5 °ATDC
                 Freeze Frame:
                        Fault Status: 01100001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 211779 km
                        Time Indication: 5
                 Freeze Frame:
                        Voltage: 11.04 V
                            DU
                        Temperature: 18.0°C
                        RPM: 1498 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Count: 0
                        Ign. Timing: -0.0 °ATDC
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ47 ELV 043 0631
       Coding: 08910A0002864E76000395157C085FCE105C01
       Subsystem 1 - Part No: 1K8 951 605 B
       Component: LIN BACKUP HORN H11 9005
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 1K0 907 951
       Component: EZE_2         H41 1614
       Coding: 00000008
       VCID: EFEB25E73E1F5E66F27-80BA
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
    Address 52: Door Elect, Pass.        Labels: None
       Revision:     Serial number: 0534
       VCID: 55A7F70F348384B698B-8000
    No ASAM data for: "" ()
    Address 53: Parking Brake        Labels: 3AA-907-801.clb
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000323937
       Coding: 0022067
       VCID: 3363699752B7BA8656F-8066
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 63
                        Reset counter: 164
                        Mileage: 211770 km
                        Time Indication: 0
                        Date: 2020.14.30
                        Time: 09:42:56
                 Freeze Frame:
                        Voltage: 14.70 V
                        Count: 71
                        Speed: 30.0 km/h
                        Hex Value: 0x1260
                        Hex Value: 0x0004
                        Hex Value: 0x0101
    Address 65: Tire Pressure (J502)       Labels: 3AA-907-273.clb
       Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
       Component: RDKBERU30     H08 0008
       Serial number: 10000000033632
       ASAM Dataset: EV_RDKBERU30 003010
       ROD: EV_RDKBERU30_SE36.rod
       VCID: 336369979AB7BA8656F-8066
    End   ---------------------------------------------------------------------
  2. Re: 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    131 Post(s)
    1973 Post(s)
    For a start you have a flat battery and some controllers are looking into the future with the wrong date, get it fully charged up, clear all the codes and try again. If it does not run, keep the battery on charge all the time, the voltage must be stable over 12 volts.
  3. Re: 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    As you can't communicate with the ECU it looks like it is either goosed ( very unlikely ) or it is missing power.
    You need a wiring diagram to check what power is missing at the ECU pins.
    As a preliminary, check all the engine bay fuses & cable connections on the front of the fuse box.
    New batteries usually don't come fully charged, so give it a good charge first.
  4. Re: 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    Apr 2020
    The battery was fully charged but the engine fan being constantly on has drained it slightly so charging it again and disconnected the fan.
    Have also checked all fuses and cable connections and they all look ok.
  5. Re: 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    If your VCDS is still unable to communicate with the ECM, I would suspect it is not getting power from the battery.
    You will need the wiring diagram & a meter to test the various ECU pins.
  6. Re: 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    Apr 2020
    Thank you for the info, it sounds like fun and really hope it doesn’t come to that.
  7. Re: 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    Apr 2020
    Fully charged battery and still no communication with VCDS, looks like a play about with the ECU.
  8. Re: 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    That's bad news then.
    I think your problem might reside in the engine bay fuse box, but you really need the wiring diagram to progress further.
    Have a look at this picture of the fuse box.
    https://www.ebay.co.uk/itm/2014-FOR-VW-PASSAT-CC-R-LINE-2-0-DIESEL-ENGINE-FUSE-BOX-3C0937125A/124040780280?hash=item1ce16819f8:g:sC0AAOSwtgxeGHp 2
    There is a plug connection on the bottom of it which could have come loose & would be reasonably easy to check.
  9. Re: 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    Apr 2020
    That plug is in fine. Thank you again, I have now removed the ECU and don’t think there is any power getting to it!?
  10. Re: 2011 Passat 2.0 Diesel not starting - 01314 - Engine Control Module issue
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Have you seen this post from a few years ago:-
    https://www.vwaudiforum.co.uk/forum/showthread.php/174689-No-power-to-the-ECU
    There is a lot of useful info mainly from Crasher from #9 onwards.
    He gives ECU pin No's & even some diagrams.
  1. Question 08 Passat 2.0TDI 140 (CBA Engine)Turbo Boost Control Sensor issue **HELP!**
    By Dermottc in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-09-2016, 04:06 PM
  2. Replies: 1
    Last Post: 23-04-2015, 08:48 PM
  3. 01314 - engine control module 49-10 - no communications Fault code
    By kizzy666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2014, 11:59 AM
  4. Replies: 5
    Last Post: 15-10-2012, 10:20 PM
  5. Comfort control module issue
    By hotdog in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-07-2008, 11:47 AM
